Date/Time: Mon, 14 Sep 2026 08:43:20 +0000
control bar button highlight error
View Count: 696
| [2020-10-13 16:33:19] |
| User845052 - Posts: 75 |
Hi I set "Custom drawing tools" as buttons in the control bar. They are line configs which are highlighted when selected. Problem is, via General>>Tool Configs, on a few occasions I have saved a config over another one which is still active and saved to a different config. I have several buttons which now highlight both of the configurations in question when one is selected, which is confusing. For quick-use tools such as line drawing the config is very important and this bug needs to be fixed. |
| [2020-10-13 17:14:02] |
| John - SC Support - Posts: 47854 |
Can you give us the step-by-step to reproduce this. We have tried a few items in terms of having different configurations for control bar buttons, but we are not seeing any bugs. The only way that we can get two control bar buttons to both be active at the same time, is when they are both drawing the same tool with the same tool config, which makes sense and is not a bug. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
