Date/Time: Wed, 23 Sep 2026 22:12:28 +0000
Missing bars. Have redownloaded and restarted. Is there an issue right now with the feed?
View Count: 792
| [2020-10-13 15:56:21] |
| User339484 - Posts: 71 |
I am missing intraday bars. I have read other threads and followed those instructions but I am still missing intraday bars. I haven't altered any settings so I am not sure what is going on. |
| [2020-10-13 16:03:47] |
Yea, its all over the place now. Half of new candles are invisible now.
| [2020-10-13 16:27:54] |
| John - SC Support - Posts: 47994 |
First, go through the process to delete and redownload the data from the point where you are seeing an issue. Refer to the instructions for this here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart If that does not fix it, then we would need to see a screenshot of what you are seeing to better understand what is happening. Follow these instructions to get us a screenshot: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-10-13 16:30:48] |
This was my fault. My SSD drive was full. I now have a new issue. When I went to update Sierra charts I guess something happen because my space as full but part of my settings are not the same anymore. My chart books are fine I fixed that but a lot of the settings and visual settings are back to standard. Are they backed up somewhere? |
| [2020-10-13 16:50:51] |
Yes, these settings are backed up in the Sierra3.cfg file in the Backups folder. Make sure you have cleared enough space on your hard drive then follow these instructions: Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File: Restoring Backup Global Configuration File Also, if you are not familiar with how to clean up space from the Sierra Chart directories, then refer to the information here: Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
