Date/Time: Wed, 12 Feb 2025 07:13:10 +0000
Using HKFE data from Sierra Chart (SCEDF) and executing through CQG
View Count: 629
[2020-10-13 13:32:55] |
User582996 - Posts: 7 |
Thank you for the responses. My main driver for swapping to SC/Denali is the 'Combine Trades Into Original Summary Trade' feature that does not work with CQG market data. Do you see any issue if I was to run HKFE data for T&S/Charting through a SC Exchange Data Feed and an AMP CQG connection to a DOM to execute trades? Would this allow me to have 'Original Summary Trade' volume data for T&S/Charting for HKFE? If I was to do this, can I just setup a SC Exchange Data Feed for HKFE directly through SC for this market data? ($25 + $23 monthly cost)? many thanks |
[2020-10-14 11:34:50] |
'Combine Trades Into Original Summary Trade' does not work with Hong Kong futures data. Only CME data. Do you see any issue if I was to run HKFE data for T&S/Charting through a SC Exchange Data Feed and an AMP CQG connection to a DOM to execute trades?
Yes this is fully supported:Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Yes you can pay directly for the Sierra Chart Exchange Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
