Date/Time: Sat, 19 Sep 2026 18:04:15 +0000
glissement
View Count: 766
| [2020-10-13 12:24:26] |
| philippe zettor - Posts: 4 |
bonjour je voudrais vous soumettre un probleme récurent j ai un slipage negatige de 1 tick systematiquement lor de la cloture de mon trade pour info je suis en simulation pourriez vous me dire d ou vien le probleme ma connection internet est en fibre optique merci de votre reponse |
| [2020-10-13 19:54:45] |
If you are using the internal Trade Simulation Mode, then refer to this particular section for an understanding of how orders are filled and why this could be the case: Trade Simulation: How Orders are Filled Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-13 19:54:51
