Date/Time: Sat, 22 Aug 2026 16:01:22 +0000
range candelstick time not showing on cross
View Count: 902
[2020-10-13 11:36:44]
User942196 - Posts: 40
Dear friends
i have on my other platform, when using range candlestick, the time the candlestick ended at the bottom end of the cross pointer. i don't know how to add it now on my new platform.
any suggestions?
M
[2020-10-13 14:51:41]
John - SC Support - Posts: 47594
Sierra Chart does not have a way to display information relative to the pointer.
If you want to see the bar End Times, then you would need to add the Bar End Time study and use the Tools Value Window to see the data. Refer to the information here:
Bar End Time
[2020-10-14 06:18:43]
Hi John
The study is not what i have.
Take a look at the photo attached at the bottom you will get it
M
Private File
[2020-10-14 11:25:17]
So is that image what you see now? So what more are you looking for? We are not understanding this request.
[2020-10-16 13:34:06]
this is a photo from my desktop. I don't see this way on my laptop and i don't know what the operation is
[2020-10-16 14:26:01]
We think the setting you are looking for is the Show Y Value and Time Boxes on the Tool Settings page. Refer to the information in this section:
Chart Drawing Tools: Chart Values Tool Configuration
[2020-10-29 10:31:51]
No, this is not it. it shows the box as floating.
i need the info in the bottom of the cross. just as in my pic.
you have any new idea?
M
[2020-10-29 13:22:19]
The information you are showing in the picture is the Time Box that we referenced above.
There is no way to have that show the End-Time of the bar. It only shows the Start Time.
If you are willing to see the value in the Tool Values Window, then you could use the Spreadsheet and just offset the bar time by 1, so the beginning of the next bar is the end of the current bar.
[2020-11-03 17:59:51]
ok so how do i see the start time on the bottom of the cross?
[2020-11-03 18:09:33]
Refer to the information in this section for Show Y Value and Time Boxes:
[2020-11-03 18:22:19]
Ackin - Posts: 1865
If you want to see the value on the price you point to through the "cross", you must use two charts. One of yours and the other with a lower resolution (smaller time frame) .... if you set the cross-linking to both, you will be able to read the value on the second chart more accurately.
It's not exactly what you want but it's probably closest to it ...
Global Cursor
Chart Drawing Tools: Global Cursor (Tools >> Global Cursor On)
Date Time Of Last Edit: 2020-11-03 18:27:43
