Date/Time: Wed, 12 Feb 2025 06:51:09 +0000
[Programming Help] - Spreadsheet study: Direct A3 result alignment between two sheets
View Count: 617
[2020-10-13 08:34:19]
User185210 - Posts: 66
I would very much appreciate some help with the following formula in a study spreadsheet
There are two charts: #1 "15 min" , #2 "1 tick range", a study spreadsheet
and I would like to have the sheet#1 results correctly aligned and computed on each sheet #2 rows.
Now I use this formula in the begining of all formulas in sheet#2 but it only works for the last 5 bars...
IF(A3>=SHEET1!A3,SHEET1!A$3,
IF(SHEET1!A4<=A3<SHEET1!A3,SHEET1!A$4,
IF(SHEET1!A5<=A3<SHEET1!A4,SHEET1!A$5,
IF(SHEET1!A6<=A3<SHEET1!A5,SHEET1!A$6,
IF(SHEET1!A7<=A3<SHEET1!A6,SHEET1!A$7,
NOVALUE)))))"
...and I would like to have it for an unlimited number of bars!
How could that be done?
Thanks a lot for any feedback,
Cheers,Paul
[2020-10-13 11:48:39]
Sawtooth - Posts: 4173
If I understand you correctly, this might work for you:
=FLOOR(A3,15/1440)
This will return the DateTime of the 15min bar corresponding to each of the 1TickRange bars.
[2020-10-13 13:03:21]
Thank you,
FLOOR(A3,15/1440) is the first part of the solution.
This example to illustrate my idea:
on sheet#1 15min chart:
sheet#1
A3 14:15:00 returned value of O3 is: 4
A4 14:00:00 returned value of O3 is: 15
A5 13:45:00 returned value of O3 is: 27
A6 13:30:00 returned value of O3 is: 5
A7 13:15:00 returned value of O3 is: 11 ...
What I would like to have extracted on sheet#2 1TickRange chart is:
sheet#2
A3 14:18:55 O3=4 (returned value from SHEET1 O3)
A4 14:16:28 O4=4 (returned value from SHEET1 O3)
A5 14:15:22 O5=4 (returned value from SHEET1 O3)
A6 14:08:21 O6=15 (returned value from SHEET1 O4)
A4 14:04:37 O7=15 (returned value from SHEET1 O4)
A7 14:00:52 O8=15 (returned value from SHEET1 O4)
A8 13:58:22 O9=27 (returned value from SHEET1 O5)
A9 13:47:12 O10=27 (returned value from SHEET1 O5)
A10 13:45:55 O11=27 (returned value from SHEET1 O5) ...
with "FLOOR(A3,15/1440)",it improves the original formula
IF(FLOOR(A3,15/1440)=SHEET1!A$3,SHEET1!O$3,
IF(FLOOR(A3,15/1440)=SHEET1!A$4,SHEET1!O$4,
IF(FLOOR(A3,15/1440)=SHEET1!A$5,SHEET1!O$5,
IF(FLOOR(A3,15/1440)=SHEET1!A$6,SHEET1!O$6,
IF(FLOOR(A3,15/1440)=SHEET1!A$7,SHEET1!O$7,NOVALUE)))))
but it still needs me to adjust it for each bar individualy
and I would like to have an automatic formula that could return all the results from sheet#1 to sheet#2
and not only the ones for which I specificaly put "O$3,O$4,O$5,O$6"...
Is there a way? thank you
[2020-10-13 13:34:11]
Try this:
On the 15min chart:
- Add the Spreadsheet Formula study, with a formula like this in the Formula field:
=ID1.SG5
where ID1 is the spreadsheet study, and SG5 is column O.
On the 1TickRange chart:
- Add the Study/Price Overlay study, set the Study to Overlay to the Spreadsheet Formula study on the 15min chart.
- On Sheet2 of the spreadsheet, in a Formula Column, use a formula like this:
=ID2.SG1@3
where ID2 is the Study/Price Overlay study.
[2020-10-13 15:55:38]
The concept works but the precision is no longer there (compared with my first solution!) Even with the matching method: "Containing Match" selected!It's either one raw ahead or one behind!
Could you suggest another way?
Thank you,
Paul
[2020-10-13 17:42:03]
When using the Study/Price Overlay study on non-time-based bars, the Data Copy Mode needs to be set to 'Earliest...'
Auto Trade System Back Testing: Performing Back Testing on a Trading System That Uses Multiple Charts
But that doesn't seem to directly solve the issue.
Try this:
- In the Study/Price Overlay study on the 1TickRange chart:
Set the Data Copy Mode to 'Earliest...'
Set the Bar Time Matching Method to 'Containing...'
- Offset the overlaid value on Sheet2 by using this formula instead:
=ID2.SG1@4
[2020-10-13 17:59:06]
Great! It works!
Thank you so much,
Cheers,
Paul
