Date/Time: Wed, 12 Feb 2025 07:11:57 +0000
Order routing service
View Count: 466
[2020-10-13 07:37:38] |
User697137 - Posts: 4 |
My brokerage is ninjatrader , and the clearing firm is phillip capital. Can i use seirra charts instead of ninjatrader plattform for trading ? What should i do?
[2020-10-13 14:31:16] |
John - SC Support - Posts: 37891 |
Refer to the information here: Using Sierra Chart with Ninja Trader Brokerage For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-13 19:30:44] |
Philip Capital does support the Sierra Chart Order Routing Service: Sierra Chart / Trading Technologies Futures Order Routing Service Your account will need to be direct with them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
