Date/Time: Wed, 12 Feb 2025 06:44:58 +0000
Market Depth Levels
View Count: 457
[2020-10-12 21:19:14] |
User736044 - Posts: 51 |
Up until last week I used to see the whole market depth with Denali, and now there are only 50 levels visible
[2020-10-13 13:26:17] |
John - SC Support - Posts: 37891 |
If you are only seeing 50 levels in the DOM, then refer to the information here: File Menu: Not Receiving the Full Number of Market Depth Levels If this is only in the Market Depth Historical Graph, then refer to this Input: Market Depth Historical Graph: Maximum Levels to Display (0 for All) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
