Date/Time: Fri, 13 Nov 2026 00:36:17 +0000
Bid and ask volume
View Count: 805
[2020-10-12 17:18:35]
User525965 - Posts: 180
Hi, I'm looking for a simple way to add to my chart the current bid and ask volume. Can you assist?
[2020-10-12 17:45:55]
John - SC Support - Posts: 48520
We would need to know what exactly you are looking for in terms of which Bid and Ask Volumes and how you want to display them.
[2020-10-12 17:58:16]
Something like this I could have somewhere on the price chart or on the side of the chart or on the top.
Since I do not use the DOM I just want something that shows me current ask/bid price and # of contracts for each.
image2020-10-12_13-56-42.png / V - Attached On 2020-10-12 17:57:34 UTC - Size: 1.39 KB - 318 views
[2020-10-12 18:22:51]
Here is a Study Collection that we have put together that will do this. You just have to make sure that you change the setting for Chart >> Chart Settings >> Advanced Settings 3 >> Number of Levels for Bid Ask Depth Calculations to 1 or you will not get just the Best Bid and Best Ask depths.
Refer to the following for how to use a Study Collection provided by Support:
Study Collections: Using a Study Collection Provided by Sierra Chart Support
attachmentBest Bid and Ask Depth Text Display.StdyCollct - Attached On 2020-10-12 18:22:40 UTC - Size: 109.16 KB - 467 views
