Date/Time: Wed, 12 Feb 2025 07:16:21 +0000
Account Balance incorrect
View Count: 477
[2020-10-12 15:32:51] |
User224836 - Posts: 2 |
Dear support team, since last week, the Account Balance data is incorrect. There is a difference about $3000. I am using latest version of SC with Stage5, Delanli/TT. Is this a bug in the current version? Any help would be appriciated. Many thanks! Andreas |
[2020-10-12 15:40:43] |
No this is not dependent on the version. Account balance data is not something that Sierra Chart has control over. See if it is correct at the end of the day.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-12 15:40:57
