Date/Time: Fri, 11 Sep 2026 16:32:51 +0000
Export several years of continuous futures tick data
View Count: 1773
| [2020-10-12 07:36:19] |
| User783093 - Posts: 27 |
I've read all I can find regarding downloading data in Sierra, but still haven't found an option to download several years of continuous futures tick data in one .txt file. I can export only symbol by symbol and this is frustrating. I know that there is an option to download bar data in chosen timeframe, but I need it in ticks. Is there a way to help me out? Thank you |
| [2020-10-12 16:05:02] |
| John - SC Support - Posts: 47848 |
Setup your chart the way you want it, in particular make it a 1 trade chart for the time frame you want. Then select Edit >> Export Bar Data to Text File. Refer to the information for this command here: Edit Menu: Edit >> Export Bar Data to Text File For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-10-12 16:18:57] |
This is not an option. Using Export Bar Data to Text File we are exporting the data of the loaded chart bars to a text file. Each record/line in the text file will represent one bar of data. I'm looking for option to export tick data. |
| [2020-10-12 17:00:05] |
What you are looking for is not supported.
