Date/Time: Sat, 13 Sep 2025 04:13:47 +0000
chartbook with intraday tickers but with real-time data disabled
View Count: 765
[2020-10-11 19:08:10]
User346098 - Posts: 50
Hi, I want to have a chartbook with intraday charts that are "frozen" in time, no new real-time data being updated into these charts, but only for these specific charts. Can this be done? also want to avoid ST: number in the status bar from rising for these charts...
[2020-10-12 06:28:22]
Refer to this setting:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html&CAID=default#DisableDataFileUpdating
[2020-10-15 10:49:54]
Hi, enabled "Disable Data File Updating" for the charts in the chartbook and indeed it stopped tracking and the ST: count reduced after reconnecting. But now I don't know what happened or what I did, the ST: count no longer goes down for the charts in I have "Disable Data File Updating".
I meticulously went through all the steps in Chart Data and Chart Data Files: Reducing Number of Symbols Being Tracked by Sierra Chart
[2020-10-15 19:17:28]
We cannot provide further help for this.
[2020-10-17 14:35:00]
That's too bad, because I closed my running version of sierrachart, downloaded fresh version of sierrachart from https://www.sierrachart.com/index.php?page=doc/SCZipInstallerList.php
logged in, closed all charts that popup with ExampleChartBook, loaded up a new ticker 'MSN' with File->Find Symbol waited for it to load then enabled 'Disable Data File Updating' disconnected and reconnected to data feed and ST:1, 1 still.
so clearly something is wrong with my account or sierra, nothing on my part.
[2020-10-18 10:52:15]
and ST:1, 1 still.
We looked into this, and it will show up as being tracked, but there is no market data subscription occurring.
Also make sure you disable this setting:
Chart Settings: Allow Real-Time Updating of Historical Chart (Chart >> Chart Settings >> Chart Data >> Chart Data menu)
