Date/Time: Wed, 12 Feb 2025 07:24:04 +0000
Ask/Bid Volume Difference Bars Pullback Column
View Count: 900
[2020-10-10 15:54:54] |
nosast - Posts: 312 |
The depth bars are always printing on bar more than the current price bar. I noticed this in v2178 and went back to 2177 where I don't see this issue. Updated today to the current version 2179 the issue is still present. Could you please fix for the next release? See attached. |
SNAG_ 2020-10-10 - 17-52-03.png / V - Attached On 2020-10-10 15:54:47 UTC - Size: 68.41 KB - 455 views |
[2020-10-10 17:44:42] |
That value is for the pullback column. We can make it optional.
[2020-10-10 20:07:09] |
Yes please. Thx |
