Date/Time: Mon, 25 Nov 2024 12:40:25 +0000
Auto Log-Off
View Count: 1071
[2014-02-10 16:59:11] |
User88901 - Posts: 33 |
Hi, how do I enable Sierra Chart to automatically logoff at a certain time or after a certain period of inactivity? Or is there a way to just disconnect automatically or something as well. I know I could probably figure it out through my broker but is it possible to do this for the Sierra Chart platform itself? Thanks.
[2014-02-10 17:18:13] |
Sierra Chart does not support this.
