Date/Time: Sun, 13 Sep 2026 00:59:37 +0000
3 minute chart stopped updating
View Count: 738
| [2020-10-09 19:06:14] |
| User923291 - Posts: 27 |
I have both a 3-minute and a 30-second chart on the screen of the same symbol. The 30-second chart is updating spontaneously but the 3-minute chart stopped at 2:36pm ET (31 minutes ago) and won't update. Global settings are at 500ms. Please advise.
| [2020-10-09 19:07:42] |
Refer to help topic 3: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-10-09 19:18:59] |
The charts are duplicates of one another with the same settings and only the period changed so settings does not appear to be the problem nor data as the one stopped spontaneously about 45 minutes ago but the other continues to run smoothly. I tried reloading data but that didn’t resolve it either. Can you provide specific suggestions to resolve this?
| [2020-10-10 07:00:35] |
Help topic 3 contains all of the possible reasons why a chart could have this problem: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Can you provide specific suggestions to resolve this?
We did just this. That page is incredibly comprehensive. Did you go through it? We are not going to rewrite what is on that page. That makes no sense.
