Date/Time: Mon, 28 Sep 2026 13:50:49 +0000
[User Discussion] - declared as reference but not initialized -- Error
View Count: 3121
[2020-10-09 16:34:22]
User681150 - Posts: 62
i keep getting this error, not sure what i am doing wrong... here is the link to the function
ACSIL Interface Members - Functions: sc.GetSessionTimesFromChart()
int GetSessionTimesFromChart(const int ChartNumber, n_ACSIL::s_ChartSessionTimes& r_ChartSessionTimes);
// mycode, errors on line 1, "error: 'chartTime' declared as reference but not initialized"
n_ACSIL::s_ChartSessionTimes& chartTime ;
sc.GetSessionTimesFromChart(chartnum,chartTime) ;
SCDateTime ch_stime = chartTime.StartTime ;
SCDateTime ch_etime = chartTime.EndTime ;
Date Time Of Last Edit: 2020-10-09 16:38:08
[2020-10-09 19:31:54]
norvik_ - Posts: 106
Hi, in c++ is impossible to declare references without being initiated.
Should be something like this
n_ACSIL::s_ChartSessionTimes& chartTime = n_ACSIL::s_ChartSessionTimes() ;//default constructor may be..
And in your case it is not necessary for declaration ChartTime as reference.
Should be declared as variable.
n_ACSIL::s_ChartSessionTimes chartTime;
Date Time Of Last Edit: 2020-10-09 20:36:37
[2020-10-12 09:25:13]
User253985 - Posts: 24
Since the update I had the same problem on my Custom Studies.
In the 'Add Study' window I get the response
The advanced custom study D:\SierraChart\Data\StudyNameBlahBlah.dll needs to be recompiled to be used on this version 2179
I went into one of the studies and initiated the reference (i think that's what it is called, hehehe)
for example I change
char PosShort;
to
char PosShort = 0;
when defining the variable
It seemed to of worked.
But i also have the problem of an amplified screen, everything is a lot bigger. I can't resolve this issue.
http://www.sierrachart.com/image.php?Image=1602494543141.png
is anyone else having this issue?
Date Time Of Last Edit: 2020-10-12 09:28:02
