Date/Time: Sat, 22 Feb 2025 17:34:44 +0000
US Stocks and Options data
View Count: 994
[2020-10-09 15:19:31] |
user75130 - Posts: 2 |
I would like to be able to use some of the studies available on Sierra Charts while trading US stocks and options on those stocks but I don't see where you have a data provider for these markets. Am I missing something? Do you have such a data provider that I am not aware of?
[2020-10-09 16:31:45] |
John - SC Support - Posts: 38116 |
You can get the U.S. Equities data from us using the Sierra Chart Exchange Data Feed. Refer to the information here: Sierra Chart Exchange Data Feed (Provides the US stock data but not stock options.) You could also get the data from IQFeed. Refer to the information here: DTN IQ Feed Data Service (You need to check with IQ Feed about the availability of stock options data) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-09 19:09:01
[2021-01-31 16:44:23] |
Chad - Posts: 234 |
My apology if this has already been answered in another thread, but: suppose I get an iqFeed subscription with access to historical market depth data for US stocks - if I open a Chart window with some stock ticker in it and enable studies 'Depth of Market Data' and 'Write Bar and Study Data To File', will that historical depth data be recorded to a .depth file in SC? To be clear, I do not need to *see* the depth data in a Chart...from reading the SB thread 'Level II using IQFeed working?', SCE made it clear in post #2 that "Stock level 2 data from IQ Feed is not supported in Sierra Chart." Date Time Of Last Edit: 2021-01-31 18:00:38
[2021-02-01 13:30:07] |
Regarding post #3, no this is not true at all. There is no support for historical market depth data from IQ Feed assuming they even have it which we do not think they do.
[2021-02-01 19:48:41] |
Chad - Posts: 234 |
You're right, my mistake.
