Date/Time: Wed, 12 Feb 2025 06:58:26 +0000
Performance Issue with Time Line Study
View Count: 520
[2020-10-09 10:39:44] |
User196369 - Posts: 41 |
I have come across a potential bug in the Time Line study which can impact system performance. On a chart of period 10 mins or greater the Time Line label will continually overwrite itself and get blacker and blacker while it is the latest bar on the chart. This causes my processer to go from 10% to about 14% usage which results in noticeable interface and screen draw lag. If I delete the study from the chart the issue disappears. This behaviour does not occur on shorter time frame charts (< 10 mins). Screen shot attached showing my settings. Appreciate if you could have a look. |
[2020-10-10 06:56:58] |
We are checking on this now.
