Date/Time: Mon, 25 Nov 2024 12:53:51 +0000
SC Real-Time feed and OEC
View Count: 2103
[2014-02-10 16:14:29] |
WarriorTrader - Posts: 245 |
Hello, I was running SC version 1070 this morning. When I logged in I did not see the [M] next to my CME symbols and the historical bid/ask data was missing. The charts were updating, but it looked like it was OCE data. The OEC Trader did say that I was connected to both the OCE Trader and SC. Trying to fix the problem I upgraded the latest version - 1090. Now SC crashes on startup as it is loading data. Does anyone else have any problems? Should I downgrade? Thx, WT Date Time Of Last Edit: 2014-02-10 16:34:07
[2014-02-10 16:33:02] |
OK, I downgraded to 1077 so now it is not crashing, but the SC Real-Time feed is still not working. The OCE Trader says I am connected to SC and the OCE Trader. Thx, WT |
[2014-02-10 16:40:24] |
. Now SC crashes on startup as it is loading data. Are you running any custom studies? For now we recommend going back to version 1078 or earlier. You can download it from here:https://www.sierrachart.com/index.php?l=doc/SCInstallerList.php To determine the source of this problem without any pressure, please install when you can, another copy of Sierra Chart into another folder on your system and start with a new Chartbook and let us know if you have a problem. When I logged in I did not see the [M] next to my CME symbols and the bid/ask data was missing.
For this we need to see the Sierra Chart Message Log. Provide it by following these steps:https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-10 16:41:08
[2014-02-10 16:57:59] |
Ok, Here is the message log. I am using 1077. 1090 crashes. It apears I am having trouble connecting to SC data because the historical data, which is coming from SC, is missing (bid/ask and price). My custom studies are working fine in 1077. So the SC-Real Time feed is not connecting. No [M] symbols next to symbols. I did update my symbol settings as instructed in the direction for setting up the SC data feed. Thx, Software version: 1077 | 2014-02-10 11:32:13 Usage end date: 2014-02-25 | 2014-02-10 11:32:13 Enabled for: Sierra Chart Historical Data Service. | 2014-02-10 11:32:13 Enabled for: Sierra Chart Real-Time Market Data Feed. | 2014-02-10 11:32:13 Enabled for: CME with exchange fee trading waiver. | 2014-02-10 11:32:13 Received 1 data feed usernames. | 2014-02-10 11:32:13 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-02-10 11:32:13 Active service: Open E Cry | 2014-02-10 11:32:13 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-02-10 11:32:13 2014-02-10 11:32:13 Local computer clock time | 2014-02-10 11:32:13 2014-02-10 16:32:13 GMT time | 2014-02-10 11:32:13 2014-02-10 11:32:13 Time zone adjusted time | 2014-02-10 11:32:13 Time difference to server time: 0 seconds. | 2014-02-10 11:32:13 Program path: C:\SierraChartOEC\ | 2014-02-10 11:32:13 Data Files path: C:\SierraChartOEC\data\ | 2014-02-10 11:32:13 OS Version Number: 5.1 | 2014-02-10 11:32:14 Checking for new symbol settings for oec | 2014-02-10 11:32:14 Checking for large (over 310 MB) intraday data files to move data out of. Please wait.... | 2014-02-10 11:32:16 Completed checking of 12 Intraday data files (*.scid). | 2014-02-10 11:32:16 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13 | 2014-02-10 11:32:17 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12 | 2014-02-10 11:32:17 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12 | 2014-02-10 11:32:17 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13 | 2014-02-10 11:32:17 Checking Intraday data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13 | 2014-02-10 11:32:17 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-08 | 2014-02-10 11:32:17 Checking Intraday data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12 | 2014-02-10 11:32:17 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-07 | 2014-02-10 11:32:17 Checking Intraday data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12 | 2014-02-10 11:32:17 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-07 | 2014-02-10 11:32:17 Checking Intraday data file for symbol ESH14 for the date range from 2013-12-12 to | 2014-02-10 11:32:17 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to | 2014-02-10 11:32:17 Symbols used for ESH14 continuous contract chart: | 2014-02-10 11:32:17 ESM13 | 2014-02-10 11:32:17 ESU13 | 2014-02-10 11:32:17 ESZ13 | 2014-02-10 11:32:17 ESH14 | 2014-02-10 11:32:17 Volume based rollover from ESM13 to ESU13 occurs at 2013-06-14 | 2014-02-10 11:32:17 Volume based rollover from ESU13 to ESZ13 occurs at 2013-09-13 | 2014-02-10 11:32:17 Volume based rollover from ESZ13 to ESH14 occurs at 2013-12-13 | 2014-02-10 11:32:17 Requesting data files from remote instance: ESH14.scid, SP#.dly | 2014-02-10 11:32:20 HD Request # 2 - Downloading Intraday chart data for $NSHF to the file $NSHF.scid. Service: ddf | 2014-02-10 11:32:21 HD Request # 2 - Download start Date-Time: 2014-02-10 11:32:06.0 | 2014-02-10 11:32:21 HD Request # 2 - Using server: ds5.sierracharts.com port 10149 | 2014-02-10 11:32:21 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-02-10 11:32:21 The network socket is connected. | 2014-02-10 11:32:21 HD Request # 2 - Sending historical data logon request message. | 2014-02-10 11:32:21 Requesting data files from remote instance: SP#.dly | 2014-02-10 11:32:21 HD Request # 3 - Downloading Historical Daily chart data for SP#. Starting date: 2014-02-07. Service: oec | 2014-02-10 11:32:21 HD Request # 3 - Using user Barchart Historical data account. | 2014-02-10 11:32:21 HD Request # 3 - Requesting historical Daily Continuous data for SPZ10 starting at 2014-02-06 | 2014-02-10 11:32:21 HD Request # 2 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2014-02-10 11:32:22 HD Request # 2 - Decompressing data. | 2014-02-10 11:32:22 HD Request # 2 - Receiving Intraday data for $NSHF starting at 2014-02-10 11:32:06 | 2014-02-10 11:32:22 HD Request # 2 - Timestamp of first Intraday data file record written: 2014-02-10 11:32:07 | 2014-02-10 11:32:22 The network socket for historical data has been closed. | 2014-02-10 11:32:22 HD Request # 2 - Historical data for $NSHF is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-02-10 11:32:22 HD Request # 2 - Received 17 records from 2014-02-10 11:32:06 to 2014-02-10 11:32:22 (16.0 seconds) and wrote 16 records for $NSHF | 2014-02-10 11:32:22 HD Request # 2 - Intraday download COMPLETE for $NSHF | 2014-02-10 11:32:22 HD Request # 4 - Downloading Intraday chart data for $NVLF to the file $NVLF.scid. Service: ddf | 2014-02-10 11:32:22 HD Request # 4 - Download start Date-Time: 2014-02-10 11:32:06.0 | 2014-02-10 11:32:22 HD Request # 4 - Using server: ds3.sierracharts.com port 10149 | 2014-02-10 11:32:22 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-02-10 11:32:22 The network socket is connected. | 2014-02-10 11:32:22 HD Request # 4 - Sending historical data logon request message. | 2014-02-10 11:32:22 HD Request # 4 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2014-02-10 11:32:23 Open E Cry: Connecting to serverprod.openecry.com. | 2014-02-10 11:32:23 HD Request # 4 - Decompressing data. | 2014-02-10 11:32:23 HD Request # 4 - Receiving Intraday data for $NVLF starting at 2014-02-10 11:32:06 | 2014-02-10 11:32:23 HD Request # 4 - Timestamp of first Intraday data file record written: 2014-02-10 11:32:07 | 2014-02-10 11:32:23 The network socket for historical data has been closed. | 2014-02-10 11:32:23 HD Request # 3 - Receiving historical Daily data for SP# starting at 2014-02-06 | 2014-02-10 11:32:24 Writing historical Daily data for SP# to the file SP#.dly | 2014-02-10 11:32:24 HD Request # 3 - Received 3 records from 2014-02-06 00:00:00 to 2014-02-10 00:00:00 (5.0 days) and wrote 2 records for SP# | 2014-02-10 11:32:24 HD Request # 3 - Daily download COMPLETE for SP# | 2014-02-10 11:32:24 HD Request # 4 - Historical data for $NVLF is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-02-10 11:32:24 HD Request # 4 - Received 17 records from 2014-02-10 11:32:06 to 2014-02-10 11:32:22 (16.0 seconds) and wrote 16 records for $NVLF | 2014-02-10 11:32:24 HD Request # 4 - Intraday download COMPLETE for $NVLF | 2014-02-10 11:32:24 HD Request # 5 - Downloading Intraday chart data for $TICK to the file $TICK.scid. Service: ddf | 2014-02-10 11:32:24 HD Request # 5 - Download start Date-Time: 2014-02-10 11:32:05.0 | 2014-02-10 11:32:24 HD Request # 5 - Using server: ds5.sierracharts.com port 10149 | 2014-02-10 11:32:24 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-02-10 11:32:24 The network socket is connected. | 2014-02-10 11:32:24 HD Request # 5 - Sending historical data logon request message. | 2014-02-10 11:32:24 HD Request # 5 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2014-02-10 11:32:24 HD Request # 5 - Decompressing data. | 2014-02-10 11:32:24 HD Request # 5 - Receiving Intraday data for $TICK starting at 2014-02-10 11:32:05 | 2014-02-10 11:32:24 HD Request # 5 - Timestamp of first Intraday data file record written: 2014-02-10 11:32:07 | 2014-02-10 11:32:24 The network socket for historical data has been closed. | 2014-02-10 11:32:24 HD Request # 5 - Historical data for $TICK is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-02-10 11:32:24 HD Request # 5 - Received 19 records from 2014-02-10 11:32:05 to 2014-02-10 11:32:23 (18.0 seconds) and wrote 18 records for $TICK | 2014-02-10 11:32:24 HD Request # 5 - Intraday download COMPLETE for $TICK | 2014-02-10 11:32:24 Open E Cry: Connected. | 2014-02-10 11:32:25 Open E Cry - Starting real-time market data updates for: VXG4 | 2014-02-10 11:32:25 Open E Cry tick subscription ID: 2 | 2014-02-10 11:32:25 HD Request # 6 - Downloading Intraday chart data for VXG4 to the file VXG4.scid. Service: oec | 2014-02-10 11:32:25 HD Request # 6 - Download start Date-Time: 2014-02-10 11:32:06.0 | 2014-02-10 11:32:25 HD Request # 6 - Requesting Historical Tick data from 2014-02-10 16:32:06 (UTC) to 2014-02-10 16:32:25 (UTC). | 2014-02-10 11:32:25 HD Request # 6 - Open E Cry history request subscription ID: 3 | 2014-02-10 11:32:25 Open E Cry - Starting real-time market data updates for: ESH4 | 2014-02-10 11:32:25 Open E Cry tick subscription ID: 5 | 2014-02-10 11:32:25 Open E Cry - Starting real-time market data updates for: GCLH4 | 2014-02-10 11:32:25 Open E Cry tick subscription ID: 7 | 2014-02-10 11:32:25 Open E Cry - Starting real-time market data updates for: DX-MH4 | 2014-02-10 11:32:25 Open E Cry tick subscription ID: 9 | 2014-02-10 11:32:25 Open E Cry - Starting real-time market data updates for: SP# | 2014-02-10 11:32:25 Symbol Error - SP# is unknown, unavailable, or improperly formatted. Failed to find the base contract. | 2014-02-10 11:32:25 Open E Cry - Starting real-time market data updates for: FDAXH4 | 2014-02-10 11:32:25 Open E Cry tick subscription ID: 11 | 2014-02-10 11:32:25 SC Market Stats - Starting real-time market data updates for: $TICK | 2014-02-10 11:32:25 SC Market Stats: Connecting to the server ds3.sierracharts.com. Port 443 | 2014-02-10 11:32:25 HD Request # 7 - Downloading Intraday chart data for $TICK to the file $TICK.scid. Service: ddf | 2014-02-10 11:32:25 HD Request # 7 - Download start Date-Time: 2014-02-10 11:32:23.0 | 2014-02-10 11:32:25 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-02-10 11:32:25 HD Request # 7 - Using server: ds5.sierracharts.com port 10149 | 2014-02-10 11:32:25 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-02-10 11:32:25 SC Market Stats - Starting real-time market data updates for: $NSHF | 2014-02-10 11:32:25 The network socket is connected. | 2014-02-10 11:32:25 SC Market Stats: Connected to server. | 2014-02-10 11:32:25 SC Market Stats: Sending logon request message. | 2014-02-10 11:32:25 Open E Cry - Starting real-time market data updates for: GHGH4 | 2014-02-10 11:32:25 Open E Cry tick subscription ID: 13 | 2014-02-10 11:32:25 The network socket is connected. | 2014-02-10 11:32:25 HD Request # 7 - Sending historical data logon request message. | 2014-02-10 11:32:25 Open E Cry - Starting real-time market data updates for: ZNH4 | 2014-02-10 11:32:25 Open E Cry tick subscription ID: 15 | 2014-02-10 11:32:25 HD Request # 6 - OEC Trading service: Request 1 for VXG4: Received 0 records. | 2014-02-10 11:32:25 HD Request # 6 - Received 0 records and wrote 0 records for VXG4 | 2014-02-10 11:32:25 HD Request # 6 - Intraday download COMPLETE for VXG4 | 2014-02-10 11:32:25 Real-time Intraday chart data file updates started for VXG4 | 2014-02-10 11:32:25 Open E Cry error: Your subscription limit of 5 has been reached | 2014-02-10 11:32:25 Sierra Chart Server Info - Server Name: SC Real-Time Server. Server Version: . Provider Name: Sierra Chart. | 2014-02-10 11:32:25 Sierra Chart - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-02-10 11:32:25 Sierra Chart - Logon error from server: : Data service (ddf) is disabled/unsupported. Update Sierra Chart to the current version. | 2014-02-10 11:32:25 Sierra Chart: Disconnected from the server. | 2014-02-10 11:32:25 Sierra Chart: Data feed disconnected. Will reconnect. | 2014-02-10 11:32:25 HD Request # 7 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2014-02-10 11:32:25 HD Request # 8 - Downloading Intraday chart data for ESH4 to the file ESH4.scid. Service: oec | 2014-02-10 11:32:25 HD Request # 7 - Decompressing data. | 2014-02-10 11:32:25 HD Request # 7 - Receiving Intraday data for $TICK starting at 2014-02-10 11:32:23 | 2014-02-10 11:32:25 HD Request # 7 - Timestamp of first Intraday data file record written: 2014-02-10 11:32:24 | 2014-02-10 11:32:25 The network socket for historical data has been closed. | 2014-02-10 11:32:25 HD Request # 8 - Download start Date-Time: 2014-02-10 11:32:06.0 | 2014-02-10 11:32:25 HD Request # 8 - Requesting Historical Tick data from 2014-02-10 16:32:06 (UTC) to 2014-02-10 16:32:25 (UTC). | 2014-02-10 11:32:25 HD Request # 8 - Open E Cry history request subscription ID: 16 | 2014-02-10 11:32:25 HD Request # 7 - Received 2 records from 2014-02-10 11:32:23 to 2014-02-10 11:32:24 (1.0 seconds) and wrote 1 record for $TICK | 2014-02-10 11:32:25 HD Request # 7 - Intraday download COMPLETE for $TICK | 2014-02-10 11:32:25 Real-time Intraday chart data file updates started for $TICK | 2014-02-10 11:32:25 HD Request # 8 - OEC Trading service: Request 1 for ESH4: Received 0 records. | 2014-02-10 11:32:25 HD Request # 8 - Received 0 records and wrote 0 records for ESH4 | 2014-02-10 11:32:25 HD Request # 8 - Intraday download COMPLETE for ESH4 | 2014-02-10 11:32:25 Real-time Intraday chart data file updates started for ESH4 | 2014-02-10 11:32:25 HD Request # 9 - Downloading Intraday chart data for $NSHF to the file $NSHF.scid. Service: ddf | 2014-02-10 11:32:25 HD Request # 9 - Download start Date-Time: 2014-02-10 11:32:22.0 | 2014-02-10 11:32:25 HD Request # 9 - Using server: ds3.sierracharts.com port 10149 | 2014-02-10 11:32:25 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-02-10 11:32:25 HD Request # 10 - Downloading Intraday chart data for GCLH4 to the file GCLH4.scid. Service: oec | 2014-02-10 11:32:25 HD Request # 10 - Download start Date-Time: 2014-02-10 11:32:06.0 | 2014-02-10 11:32:25 The network socket is connected. | 2014-02-10 11:32:25 HD Request # 9 - Sending historical data logon request message. | 2014-02-10 11:32:25 HD Request # 9 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2014-02-10 11:32:25 HD Request # 10 - Requesting Historical Tick data from 2014-02-10 16:32:06 (UTC) to 2014-02-10 16:32:25 (UTC). | 2014-02-10 11:32:25 HD Request # 10 - Open E Cry history request subscription ID: 17 | 2014-02-10 11:32:25 Sierra Chart - Starting real-time market data updates for: $NVLF | 2014-02-10 11:32:25 SC Market Stats: Connecting to the server ds5.sierracharts.com. Port 443 | 2014-02-10 11:32:25 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-02-10 11:32:25 The network socket is connected. | 2014-02-10 11:32:26 SC Market Stats: Connected to server. | 2014-02-10 11:32:26 SC Market Stats: Sending logon request message. | 2014-02-10 11:32:26 HD Request # 9 - Decompressing data. | 2014-02-10 11:32:26 HD Request # 9 - Receiving Intraday data for $NSHF starting at 2014-02-10 11:32:22 | 2014-02-10 11:32:26 HD Request # 9 - Timestamp of first Intraday data file record written: 2014-02-10 11:32:23 | 2014-02-10 11:32:26 The network socket for historical data has been closed. | 2014-02-10 11:32:26 HD Request # 9 - Received 4 records from 2014-02-10 11:32:22 to 2014-02-10 11:32:25 (3.0 seconds) and wrote 3 records for $NSHF | 2014-02-10 11:32:26 HD Request # 9 - Intraday download COMPLETE for $NSHF | 2014-02-10 11:32:26 Real-time Intraday chart data file updates started for $NSHF | 2014-02-10 11:32:26 HD Request # 11 - Downloading Intraday chart data for $NVLF to the file $NVLF.scid. Service: ddf | 2014-02-10 11:32:26 HD Request # 11 - Download start Date-Time: 2014-02-10 11:32:22.0 | 2014-02-10 11:32:26 HD Request # 11 - Using server: ds3.sierracharts.com port 10149 | 2014-02-10 11:32:26 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-02-10 11:32:26 SC Market Stats Server Info - Server Name: . Server Version: . Provider Name: . | 2014-02-10 11:32:26 The network socket is connected. | 2014-02-10 11:32:26 HD Request # 11 - Sending historical data logon request message. | 2014-02-10 11:32:26 SC Market Stats - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-02-10 11:32:26 SC Market Stats - Successfully connected. | 2014-02-10 11:32:26 SC Market Stats - Restarting real-time data updates for symbol: $NSHF | 2014-02-10 11:32:26 SC Market Stats - Restarting real-time data updates for symbol: $NVLF | 2014-02-10 11:32:26 SC Market Stats - Restarting real-time data updates for symbol: $TICK | 2014-02-10 11:32:26 HD Request # 10 - OEC Trading service: Request 1 for GCLH4: Received 0 records. | 2014-02-10 11:32:26 HD Request # 10 - Received 0 records and wrote 0 records for GCLH4 | 2014-02-10 11:32:26 HD Request # 10 - Timestamp of first Intraday data file record written: 2014-02-10 11:32:25 | 2014-02-10 11:32:26 Added 3 Time and Sales records to Intraday data file for GCLH4 after download. | 2014-02-10 11:32:26 HD Request # 10 - Intraday download COMPLETE for GCLH4 | 2014-02-10 11:32:26 Real-time Intraday chart data file updates started for GCLH4 | 2014-02-10 11:32:26 HD Request # 11 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2014-02-10 11:32:26 HD Request # 11 - Decompressing data. | 2014-02-10 11:32:26 HD Request # 11 - Receiving Intraday data for $NVLF starting at 2014-02-10 11:32:22 | 2014-02-10 11:32:26 HD Request # 11 - Timestamp of first Intraday data file record written: 2014-02-10 11:32:23 | 2014-02-10 11:32:26 The network socket for historical data has been closed. | 2014-02-10 11:32:26 HD Request # 12 - Downloading Intraday chart data for DX-MH4 to the file DX-MH4.scid. Service: oec | 2014-02-10 11:32:26 HD Request # 12 - Download start Date-Time: 2014-02-10 11:29:35.0 | 2014-02-10 11:32:26 HD Request # 12 - Requesting Historical Tick data from 2014-02-10 16:29:35 (UTC) to 2014-02-10 16:32:26 (UTC). | 2014-02-10 11:32:26 HD Request # 12 - Open E Cry history request subscription ID: 18 | 2014-02-10 11:32:26 HD Request # 11 - Received 4 records from 2014-02-10 11:32:22 to 2014-02-10 11:32:25 (3.0 seconds) and wrote 3 records for $NVLF | 2014-02-10 11:32:26 HD Request # 11 - Intraday download COMPLETE for $NVLF | 2014-02-10 11:32:26 Real-time Intraday chart data file updates started for $NVLF | 2014-02-10 11:32:26 HD Request # 13 - Downloading Intraday chart data for $NSHF to the file $NSHF.scid. Service: ddf | 2014-02-10 11:32:26 HD Request # 13 - Download start Date-Time: 2014-02-10 11:32:25.0 | 2014-02-10 11:32:26 HD Request # 13 - Using server: ds5.sierracharts.com port 10149 | 2014-02-10 11:32:26 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-02-10 11:32:26 The network socket is connected. | 2014-02-10 11:32:26 HD Request # 13 - Sending historical data logon request message. | 2014-02-10 11:32:26 HD Request # 13 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2014-02-10 11:32:26 HD Request # 13 - Decompressing data. | 2014-02-10 11:32:26 HD Request # 13 - Receiving Intraday data for $NSHF starting at 2014-02-10 11:32:25 | 2014-02-10 11:32:26 HD Request # 13 - Timestamp of first Intraday data file record written: 2014-02-10 11:32:26 | 2014-02-10 11:32:26 The network socket for historical data has been closed. | 2014-02-10 11:32:26 HD Request # 13 - Received 2 records from 2014-02-10 11:32:25 to 2014-02-10 11:32:26 (1.0 seconds) and wrote 1 record for $NSHF | 2014-02-10 11:32:26 HD Request # 13 - Intraday download COMPLETE for $NSHF | 2014-02-10 11:32:26 Real-time Intraday chart data file updates started for $NSHF | 2014-02-10 11:32:26 HD Request # 14 - Downloading Intraday chart data for $TICK to the file $TICK.scid. Service: ddf | 2014-02-10 11:32:26 HD Request # 14 - Download start Date-Time: 2014-02-10 11:32:24.0 | 2014-02-10 11:32:26 HD Request # 14 - Using server: ds3.sierracharts.com port 10149 | 2014-02-10 11:32:26 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-02-10 11:32:26 The network socket is connected. | 2014-02-10 11:32:26 HD Request # 14 - Sending historical data logon request message. | 2014-02-10 11:32:26 HD Request # 14 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2014-02-10 11:32:26 HD Request # 14 - Decompressing data. | 2014-02-10 11:32:26 HD Request # 14 - Receiving Intraday data for $TICK starting at 2014-02-10 11:32:25 | 2014-02-10 11:32:26 HD Request # 14 - Timestamp of first Intraday data file record written: 2014-02-10 11:32:25 | 2014-02-10 11:32:26 The network socket for historical data has been closed. | 2014-02-10 11:32:26 HD Request # 14 - Received 3 records from 2014-02-10 11:32:25 to 2014-02-10 11:32:26 (1.0 seconds) and wrote 3 records for $TICK | 2014-02-10 11:32:26 HD Request # 14 - Intraday download COMPLETE for $TICK | 2014-02-10 11:32:26 Real-time Intraday chart data file updates started for $TICK | 2014-02-10 11:32:26 HD Request # 12 - OEC Trading service: Receiving intraday tick data for DX-MH4. (Subscription ID: 18) | 2014-02-10 11:32:27 HD Request # 12 - OEC Trading service: Request 1 for DX-MH4: Received 57 records from 2/10/2014 11:29:35 AM to 2/10/2014 11:31:26 AM. | 2014-02-10 11:32:27 HD Request # 12 - Requesting Historical Tick data from 2014-02-10 16:29:35 (UTC) to 2014-02-10 16:29:35 (UTC). | 2014-02-10 11:32:27 HD Request # 12 - Open E Cry history request subscription ID: 19 | 2014-02-10 11:32:27 HD Request # 12 - OEC Trading service: Request 2 for DX-MH4: Received 0 records. | 2014-02-10 11:32:27 HD Request # 12 - Receiving Intraday data for DX-MH4 starting at 2014-02-10 11:29:35 | 2014-02-10 11:32:27 HD Request # 12 - Timestamp of first Intraday data file record written: 2014-02-10 11:29:50 | 2014-02-10 11:32:27 HD Request # 12 - Received 57 records from 2014-02-10 11:29:35 to 2014-02-10 11:31:26 (111.0 seconds) and wrote 56 records for DX-MH4 | 2014-02-10 11:32:27 Added 1 Time and Sales records to Intraday data file for DX-MH4 after download. | 2014-02-10 11:32:27 HD Request # 12 - Intraday download COMPLETE for DX-MH4 | 2014-02-10 11:32:27 Real-time Intraday chart data file updates started for DX-MH4 | 2014-02-10 11:32:27 HD Request # 15 - Downloading Intraday chart data for FDAXH4 to the file FDAXH4.scid. Service: oec | 2014-02-10 11:32:27 HD Request # 15 - Download start Date-Time: 2014-02-10 11:32:06.0 | 2014-02-10 11:32:27 HD Request # 15 - Requesting Historical Tick data from 2014-02-10 16:32:06 (UTC) to 2014-02-10 16:32:27 (UTC). | 2014-02-10 11:32:27 HD Request # 15 - Open E Cry history request subscription ID: 20 | 2014-02-10 11:32:27 HD Request # 15 - OEC Trading service: Request 1 for FDAXH4: Received 0 records. | 2014-02-10 11:32:28 HD Request # 15 - Received 0 records and wrote 0 records for FDAXH4 | 2014-02-10 11:32:28 HD Request # 15 - Timestamp of first Intraday data file record written: 2014-02-10 11:32:26 | 2014-02-10 11:32:28 Added 1 Time and Sales records to Intraday data file for FDAXH4 after download. | 2014-02-10 11:32:28 HD Request # 15 - Intraday download COMPLETE for FDAXH4 | 2014-02-10 11:32:28 Real-time Intraday chart data file updates started for FDAXH4 | 2014-02-10 11:32:28 HD Request # 16 - Downloading Intraday chart data for GHGH4 to the file GHGH4.scid. Service: oec | 2014-02-10 11:32:28 HD Request # 16 - Download start Date-Time: 2014-02-10 11:31:52.0 | 2014-02-10 11:32:28 HD Request # 16 - Requesting Historical Tick data from 2014-02-10 16:31:52 (UTC) to 2014-02-10 16:32:28 (UTC). | 2014-02-10 11:32:28 HD Request # 16 - Open E Cry history request subscription ID: 21 | 2014-02-10 11:32:28 HD Request # 16 - OEC Trading service: Request 1 for GHGH4: Received 0 records. | 2014-02-10 11:32:28 HD Request # 16 - Received 0 records and wrote 0 records for GHGH4 | 2014-02-10 11:32:28 HD Request # 16 - Intraday download COMPLETE for GHGH4 | 2014-02-10 11:32:28 Real-time Intraday chart data file updates started for GHGH4 | 2014-02-10 11:32:28 HD Request # 17 - Downloading Intraday chart data for ZNH4 to the file ZNH4.scid. Service: oec | 2014-02-10 11:32:28 HD Request # 17 - Download start Date-Time: 2014-02-10 10:55:41.0 | 2014-02-10 11:32:28 HD Request # 17 - Requesting Historical Tick data from 2014-02-10 15:55:41 (UTC) to 2014-02-10 16:32:28 (UTC). | 2014-02-10 11:32:28 HD Request # 17 - Open E Cry history request subscription ID: 22 | 2014-02-10 11:32:28 HD Request # 17 - OEC Trading service: Receiving intraday tick data for ZNH4. (Subscription ID: 22) | 2014-02-10 11:32:29 HD Request # 17 - OEC Trading service: Request 1 for ZNH4: Received 7864 records from 2/10/2014 10:55:41 AM to 2/10/2014 11:31:22 AM. | 2014-02-10 11:32:29 HD Request # 17 - Requesting Historical Tick data from 2014-02-10 15:55:41 (UTC) to 2014-02-10 15:55:41 (UTC). | 2014-02-10 11:32:30 HD Request # 17 - Open E Cry history request subscription ID: 23 | 2014-02-10 11:32:30 HD Request # 17 - OEC Trading service: Request 2 for ZNH4: Received 0 records. | 2014-02-10 11:32:30 HD Request # 17 - Receiving Intraday data for ZNH4 starting at 2014-02-10 10:55:41 | 2014-02-10 11:32:30 HD Request # 17 - Timestamp of first Intraday data file record written: 2014-02-10 10:55:43 | 2014-02-10 11:32:30 HD Request # 17 - Received 7864 records from 2014-02-10 10:55:41 to 2014-02-10 11:31:22 (35.7 minutes) and wrote 7863 records for ZNH4 | 2014-02-10 11:32:30 HD Request # 17 - Intraday download COMPLETE for ZNH4 | 2014-02-10 11:32:30 Real-time Intraday chart data file updates started for ZNH4 | 2014-02-10 11:32:30 Chart #8 has tagged chart #11 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:32 Chart #8 has tagged chart #15 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:32 Chart #8 has tagged chart #3 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:32 Chart #8 has tagged chart #11 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:32 Chart #8 has tagged chart #15 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:32 Chart #8 has tagged chart #3 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:32 Chart #8 has tagged chart #11 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:32 Chart #8 has tagged chart #15 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:32 Chart #8 has tagged chart #3 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:32 Chart #3 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:32 Chart #15 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:32 Chart #11 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:32 Chart #1 has tagged chart #12 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #13 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #14 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #17 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #18 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #19 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #2 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #22 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #23 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #24 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #25 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #8 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #12 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #13 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #14 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #17 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #18 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #19 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #2 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #22 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #23 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #24 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #25 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #8 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #12 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #13 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #14 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #17 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #18 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #19 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #2 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #22 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #23 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #24 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #25 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #1 has tagged chart #8 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #25 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #18 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #13 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Circular chart reference detected. Charts: 1, 13. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht. | 2014-02-10 11:32:33 Chart #13 has tagged chart #8 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #19 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #22 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #23 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #14 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #8 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #8 has tagged chart #11 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #8 has tagged chart #15 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #8 has tagged chart #3 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #17 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #24 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #12 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #3 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #15 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #11 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:33 Chart #2 has tagged chart #1 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #2 has tagged chart #8 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #2 has tagged chart #1 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #2 has tagged chart #8 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #8 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #8 has tagged chart #11 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #8 has tagged chart #15 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #8 has tagged chart #3 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #3 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #15 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #1 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #1 has tagged chart #12 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Circular chart reference detected. Charts: 13, 1. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht. | 2014-02-10 11:32:35 Chart #1 has tagged chart #14 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #1 has tagged chart #17 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #1 has tagged chart #18 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #1 has tagged chart #19 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Circular chart reference detected. Charts: 2, 1. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht. | 2014-02-10 11:32:35 Chart #1 has tagged chart #22 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #1 has tagged chart #23 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #1 has tagged chart #24 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #1 has tagged chart #25 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #1 has tagged chart #8 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #11 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #19 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #22 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #23 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #14 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #8 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #8 has tagged chart #11 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #8 has tagged chart #15 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #8 has tagged chart #3 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:35 Chart #17 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:36 Chart #24 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:36 Chart #12 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:36 Chart #25 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:36 Chart #18 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:36 Chart #3 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:36 Chart #15 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:36 Chart #11 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:32:36 Chart #5 has tagged chart #24 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:37:40 Chart #24 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:37:40 Chart #5 has tagged chart #24 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:38:05 Chart #24 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:38:05 Chart #5 has tagged chart #24 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:38:26 Chart #24 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:38:27 Chart #5 has tagged chart #24 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:38:28 Chart #24 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:38:28 Chart #5 has tagged chart #24 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:38:29 Chart #24 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:38:29 Chart #5 has tagged chart #24 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:38:54 Chart #24 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:38:54 Chart #5 has tagged chart #24 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:39:05 Chart #24 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:39:05 Chart #5 has tagged chart #24 for full recalculation. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:39:09 Chart #24 is performing a full recalculation because it has been tagged. Chartbook: BidAskBarsOnP&F_5TickReversal_IQ_OEC.cht | 2014-02-10 11:39:09 |
[2014-02-10 17:11:57] |
There are two problems here: You appear to be missing the Symbol Settings. Update the Symbol Settings as explained here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings At least one of the ES charts is using data from a remote instance of Sierra Chart. You need to reselect the symbol for that chart and use the data from the OEC instance (instance the chart is open within), by following the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_SwitchingSymbols.html#ChangingChartSymbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-10 17:25:34] |
At least one of the ES charts is using data from a remote instance of Sierra Chart. You need to reselect the symbol for that chart and use the data from the OEC instance (instance the chart is open within), by following the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_SwitchingSymbols.html#ChangingChartSymbol -------------------------------------------------------------------------------- Hello, I use the remote version for my continuous daily charts. It is the SC Historical minute data, so I don't have to load a lot of tick data. This has worked for over a month now. Why would this be causing a problem? I am going to submit a chartbook with only one symbol and no studies. Thx, WT |
[2014-02-10 17:27:04] |
We also said this: You appear to be missing the Symbol Settings. Update the Symbol Settings as explained here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings You might even want to perform a Full Reset of the symbol settings. The chart that is using data from remote instance, that is OK as long as you understand it is not going to get data from the Sierra Chart Real-time and Historical Data feed. We do not need a Chartbook. Please do not submit it. We do not need anything unnecessary please. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-10 17:28:09
[2014-02-10 17:42:31] |
Hello, I meant I would submit the message log of the chartbook. My mistake. I did the reset but it did not help. The Full Reset did the trick. It is working now. Thx. Thx, WT Hope you can fix 1090 so I can use the OEC FIX conection. I am hapy with version 1077 for now though. |
[2014-02-10 17:48:04] |
We are not aware of a problem that would cause an abnormal shutdown when using 1090. We suspect that it is related to the custom studies you are using. You may want to recompile them on 1090. Are these your own studies? Not sure why recompile would be needed, perhaps there was an inadvertent change causing a need for that for the custom studies you are using.
[2014-02-10 18:01:19] |
I used Microsoft Visual C++ 2008 Express to compile them. This should be fine right? Ok, I will take them all out over the weekend and upgrade. Yes, they are my own studies. Thx, WT Date Time Of Last Edit: 2014-02-10 18:02:51
[2014-02-10 18:05:37] |
Yes, that compiler will work fine.
