Date/Time: Wed, 12 Feb 2025 07:22:10 +0000
"Transparency Level for Fill Styles" seems inert
View Count: 1358
[2020-10-08 23:17:31] |
User203781 - Posts: 55 |
I have been using High/Low for Time Period - Extended to display the opening range. Draw Style is set to Fill Top and Fill Bottom. The fill is dark enough to be distracting, so I have been trying to increase transparency. The default level seems to be 100. Despite this, the fill comes up solidly colored: When I set it to green, the density is the same as the fill of the up bars. Changing the Transparency Level setting has no effect. What am I doing wrong? Thanks. |
[2020-10-09 05:49:01] |
Ackin - Posts: 1865 |
Try Changing drawstyle to "Transparent Fill TOP" and "Transparent Fill Bottom" and then the transparency level setting will work
[2020-10-09 09:09:41] |
You need to use these Draw Styles instead: Chart Studies: Transparent Fill Top (ACSIL: DRAWSTYLE_TRANSPARENT_FILL_TOP) and Transparent Fill Bottom (ACSIL: DRAWSTYLE_TRANSPARENT_FILL_BOTTOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
