Date/Time: Wed, 12 Feb 2025 06:55:52 +0000
Error Order fills
View Count: 426
[2020-10-08 18:50:15]
Chap - Posts: 39
hello, i really need your help, how can i fixed the messiness of the order fills, I have check what you have told me in the old post, i like sierra, but this problem is really uncomfortable
look the imagine attached, a complete mess
imageerror order fills.png / V - Attached On 2020-10-08 18:47:02 UTC - Size: 79.76 KB - 173 views
[2020-10-08 19:22:56]
We cannot tell what you mean from that chart image.
What is the problem?
[2020-10-08 19:33:29]
Chap - Posts: 39
The colors, the connection lines are wrong. for example for a short trade the color should be red for the entry and blue the exits with connection lines. but my trades show green colors instead of blue sometimes, sometimes in front of the entry (red or green) appear a blue mark. the connection lines connect to old trades. in this way I cannot review my trades properly.
the same problem happen if I just select to display the fills just for the current day.
