Date/Time: Wed, 12 Feb 2025 07:20:49 +0000
Heiken Ashi study on RTH Chart
View Count: 494
[2020-10-08 16:55:15] |
indigominds - Posts: 6 |
I was wondering if you could have the heiken ashi study reset at the start of each RTH session. Right now at the beginning of every RTH session its results are a little wonky.I have attached a chart to show exactly what I am talking about. Thank you. http://www.sierrachart.com/image.php?Image=1602176025997.png Date Time Of Last Edit: 2020-10-08 16:55:31
[2020-10-08 19:39:27] |
You will need to make this change. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
