Date/Time: Wed, 12 Feb 2025 07:14:41 +0000
CME data feed requirements-
View Count: 439
[2020-10-08 14:55:21] |
User238343 - Posts: 20 |
I have 2 copies of sierra chart running on my same computer. does that consider as a 2 connections by CME. because i am hoping to add a new data feed for some other purpose. if sieera is counted as 2 it will make it 3 with new feed and i will be professional user. please advise.
Date Time Of Last Edit: 2020-10-08 14:56:15
[2020-10-08 21:44:36] |
This is only one connection if using a sub instance: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-08 21:44:58
