Date/Time: Wed, 12 Feb 2025 06:52:01 +0000
missing number bars option
View Count: 591
[2020-10-08 13:41:12]
User847553 - Posts: 18
Hi, I am using the latest version (2177 64-bit 33544) of Sierra Chart. In the following webpage, there is an option called "Diagonal Bid/Ask Extreme Marker Threshold"
https://www.sierrachart.com/index.php?page=doc/NumbersBars.php#Input_DiagonalBidAskExtremeMarkerThreshold
But I cannot see it in the Numbers Bar setting (attached). Could you please tell me where I can find it.
Many thanks
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=44218
Date Time Of Last Edit: 2020-10-08 13:41:56
[2020-10-08 21:53:23]
John - SC Support - Posts: 37891
That option doesn't actually exist for customers. It was something that was worked on but never generally released. It was a mistake that it got put into the documentation. Sorry about that. We will take it out.
[2020-10-10 08:13:18]
if that is the case, where can I set the Diagonal Bid/Ask Extreme Marker Threshold? (in the setting of another study, perhaps?)
so that an arrow pointing up is placed next to a Numbers bar that has a diagonal Ask to Bid ratio greater than the entered value ; and an arrow pointing down is placed next to a Numbers bar that has a diagonal Bid to Ask ratio greater than the entered value .
Thank you
Date Time Of Last Edit: 2020-10-10 08:13:53
[2020-10-12 13:38:01]
You would want to use the Volume at Price Threshold Alert V2. Refer to the information here:
[2020-10-13 11:06:15]
Thank you very much
This case can be closed.
