Date/Time: Wed, 12 Feb 2025 04:09:56 +0000
Renko Brick with Wicks
View Count: 725
[2020-10-07 20:20:51] |
User822445 - Posts: 75 |
Hello there, I also like to use the Renko Brick with Wicks chart but it shows the same chart as candlestick chart. Renko Brick with Wicks is supposed to be the same as Mean Renko bar chart, do you have them on your platform? Regards, A |
[2020-10-07 22:00:44] |
John - SC Support - Posts: 37891 |
Yes, you need to set the Chart >> Chart Settings >> Time Period per Bar to one of the Renko options. Refer to the information in this section: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TimePeriodPerBar You would then want to use the Renko Brick with Wicks for the Draw Style. Also refer to this section on Renko bars in general: Renko Bar Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
