Date/Time: Wed, 12 Feb 2025 04:34:53 +0000
Upgrade to version over 2102
View Count: 570
[2020-10-07 15:47:43] |
User657945 - Posts: 226 |
Hi I remember there were some thread here on support board about upgrade to version 2104 and over :there's a big change in SW that impact in such a way the existing charts and studies something like a backup of chart is created in the PC etc, but I would like to be sure to what really remain or get lost in case of upgrade to this version before to do it. thx Alberto |
[2020-10-07 16:05:41] |
Ackin - Posts: 1865 |
Look: https://www.sierrachart.com/index.php?page=doc/Whats_New.php&p=1#SCVer2104 Backup Chartbook Chartbooks (Workspaces): Accessing a Backup Chartbook File If you have a very important chart with different studies and their settings, I recommend creating a collection of studies. Study Collections |
[2020-10-07 18:59:18] |
You can safely update without any concern. Backups of Chartbooks are always maintained. And you will not have any problem.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-07 18:59:38
[2020-10-08 01:01:26] |
User90125 - Posts: 715 |
Unless you upgrade to a version higher than v2155, and have custom studies, that is. Version 2151 Available: Foundation For Millisecond/Microsecond Timestamping Custom studies have to be rebuilt on 2155 or higher to use them with 2155 or higher. Although the change occurred at version 2151, there were subsequent changes and now ACSIL custom studies have to be recompiled using Sierra Chart version 2155 or higher.
Note that the current version of SC is v2177. https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2177 |
