Date/Time: Mon, 25 Nov 2024 12:14:43 +0000
Connection issues via OEC
View Count: 2198
[2014-02-10 15:05:12] |
User79157 - Posts: 22 |
My charts are not updating accurately, and I have to disconnect/reconnect in order for them to update. Could you please help me with this issue?
[2014-02-10 15:21:26] |
Sierra Chart - Max - Posts: 5730 |
How many symbols do you have open? OEC limits real-time updates to only 5 symbols. For more information, please refer to the Symbols section here: http://www.sierrachart.com/index.php?l=doc/openecry.php#Symbols Sierra Chart Support |
[2014-02-10 15:23:30] |
I only open one symbol at a time. To give you a better idea, my friend is running the exact software and his prices update as they should. I need someone to connect to me, because I feel its a technical error
[2014-02-10 15:26:43] |
Please post a copy of the Message Log following the steps here: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support |
[2014-02-10 15:34:20] |
Software version: 1090 | 2014-02-10 07:08:16 Usage end date: 2014-05-31 | 2014-02-10 07:08:16 Enabled for: Sierra Chart Historical Data Service. | 2014-02-10 07:08:16 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-02-10 07:08:16 Active service: Open E Cry FIX/FAST | 2014-02-10 07:08:16 Time Zone: -08:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-02-10 07:08:16 2014-02-10 07:08:16 Local computer clock time | 2014-02-10 07:08:16 2014-02-10 15:08:16 GMT time | 2014-02-10 07:08:16 2014-02-10 07:08:16 Time zone adjusted time | 2014-02-10 07:08:16 Time difference to server time: 4 seconds. | 2014-02-10 07:08:16 Program path: C:\SierraChart\ | 2014-02-10 07:08:16 Data Files path: C:\SierraChart\Data\ | 2014-02-10 07:08:16 OS Version Number: 6.1 | 2014-02-10 07:08:16 Checking for new symbol settings for oec | 2014-02-10 07:08:16 Symbol settings are up-to-date for oec | 2014-02-10 07:08:17 Date rule based rollover from ZFH11 to next contract occurs at 2011-02-24 | 2014-02-10 07:08:19 Date rule based rollover from ZFM11 to next contract occurs at 2011-05-27 | 2014-02-10 07:08:19 Date rule based rollover from ZFU11 to next contract occurs at 2011-08-29 | 2014-02-10 07:08:19 Date rule based rollover from ZFZ11 to next contract occurs at 2011-11-28 | 2014-02-10 07:08:19 Date rule based rollover from ZFH12 to next contract occurs at 2012-02-27 | 2014-02-10 07:08:19 Date rule based rollover from ZFM12 to next contract occurs at 2012-05-29 | 2014-02-10 07:08:19 Date rule based rollover from ZFU12 to next contract occurs at 2012-08-29 | 2014-02-10 07:08:19 Date rule based rollover from ZFZ12 to next contract occurs at 2012-11-28 | 2014-02-10 07:08:19 Date rule based rollover from ZFH13 to next contract occurs at 2013-02-26 | 2014-02-10 07:08:19 Date rule based rollover from ZFM13 to next contract occurs at 2013-05-29 | 2014-02-10 07:08:19 Date rule based rollover from ZFU13 to next contract occurs at 2013-08-28 | 2014-02-10 07:08:19 Date rule based rollover from ZFZ13 to next contract occurs at 2013-11-27 | 2014-02-10 07:08:19 Date rule based rollover from ZFH14 to next contract occurs at 2014-02-26 | 2014-02-10 07:08:19 Checking Daily data file for symbol ZFH11 for the date range from 2010-11-26 to 2011-02-19 | 2014-02-10 07:08:19 Checking Daily data file for symbol ZFM11 for the date range from 2011-02-24 to 2011-05-22 | 2014-02-10 07:08:19 Checking Daily data file for symbol ZFU11 for the date range from 2011-05-27 to 2011-08-24 | 2014-02-10 07:08:19 Checking Daily data file for symbol ZFZ11 for the date range from 2011-08-29 to 2011-11-23 | 2014-02-10 07:08:19 Checking Daily data file for symbol ZFH12 for the date range from 2011-11-28 to 2012-02-22 | 2014-02-10 07:08:19 Checking Daily data file for symbol ZFM12 for the date range from 2012-02-27 to 2012-05-24 | 2014-02-10 07:08:19 Checking Daily data file for symbol ZFU12 for the date range from 2012-05-29 to 2012-08-24 | 2014-02-10 07:08:19 Checking Daily data file for symbol ZFZ12 for the date range from 2012-08-29 to 2012-11-23 | 2014-02-10 07:08:19 Checking Daily data file for symbol ZFH13 for the date range from 2012-11-28 to 2013-02-21 | 2014-02-10 07:08:19 Checking Daily data file for symbol ZFM13 for the date range from 2013-02-26 to 2013-05-24 | 2014-02-10 07:08:19 Checking Daily data file for symbol ZFU13 for the date range from 2013-05-29 to 2013-08-23 | 2014-02-10 07:08:19 Checking Daily data file for symbol ZFZ13 for the date range from 2013-08-28 to 2013-11-22 | 2014-02-10 07:08:19 Checking Daily data file for symbol ZFH14 for the date range from 2013-11-27 to 0 | 2014-02-10 07:08:19 Symbols used for ZFH14 continuous contract chart: | 2014-02-10 07:08:19 ZFH11 | 2014-02-10 07:08:19 ZFM11 | 2014-02-10 07:08:19 ZFU11 | 2014-02-10 07:08:19 ZFZ11 | 2014-02-10 07:08:19 ZFH12 | 2014-02-10 07:08:19 ZFM12 | 2014-02-10 07:08:19 ZFU12 | 2014-02-10 07:08:19 ZFZ12 | 2014-02-10 07:08:19 ZFH13 | 2014-02-10 07:08:19 ZFM13 | 2014-02-10 07:08:19 ZFU13 | 2014-02-10 07:08:19 ZFZ13 | 2014-02-10 07:08:19 ZFH14 | 2014-02-10 07:08:19 Volume based rollover from ZFH11 to ZFM11 occurs at 2011-02-28 | 2014-02-10 07:08:19 Volume based rollover from ZFM11 to ZFU11 occurs at 2011-05-31 | 2014-02-10 07:08:19 Volume based rollover from ZFU11 to ZFZ11 occurs at 2011-08-31 | 2014-02-10 07:08:19 Volume based rollover from ZFZ11 to ZFH12 occurs at 2011-11-30 | 2014-02-10 07:08:19 Volume based rollover from ZFH12 to ZFM12 occurs at 2012-02-29 | 2014-02-10 07:08:19 Volume based rollover from ZFM12 to ZFU12 occurs at 2012-05-31 | 2014-02-10 07:08:19 Volume based rollover from ZFU12 to ZFZ12 occurs at 2012-08-31 | 2014-02-10 07:08:19 Volume based rollover from ZFZ12 to ZFH13 occurs at 2012-11-30 | 2014-02-10 07:08:19 Volume based rollover from ZFH13 to ZFM13 occurs at 2013-02-28 | 2014-02-10 07:08:19 Volume based rollover from ZFM13 to ZFU13 occurs at 2013-05-31 | 2014-02-10 07:08:19 Volume based rollover from ZFU13 to ZFZ13 occurs at 2013-08-30 | 2014-02-10 07:08:19 Volume based rollover from ZFZ13 to ZFH14 occurs at 2013-11-29 | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: Performing continuous futures contract back adjustment calculations. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFH11 Open price on 2011-02-28 is 117.7266. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFM11 Open price on 2011-02-28 is 116.8125. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFH11 price difference to ZFM11 is -0.91409999. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFM11 Open price on 2011-05-31 is 120.1953. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFU11 Open price on 2011-05-31 is 119.125. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFM11 price difference to ZFU11 is -1.0703. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFU11 Open price on 2011-08-31 is 123.5938. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFZ11 Open price on 2011-08-31 is 122.6641. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFU11 price difference to ZFZ11 is -0.92969936. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFZ11 Open price on 2011-11-30 is 123.1016. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFH12 Open price on 2011-11-30 is 122.7422. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFZ11 price difference to ZFH12 is -0.35939723. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFH12 Open price on 2012-02-29 is 123.4766. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFM12 Open price on 2012-02-29 is 123.3594. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFH12 price difference to ZFM12 is -0.11720211. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFM12 Open price on 2012-05-31 is 124.3281. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFU12 Open price on 2012-05-31 is 124.1406. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFM12 price difference to ZFU12 is -0.18749788. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFU12 Open price on 2012-08-31 is 124.6406. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFZ12 Open price on 2012-08-31 is 124.3594. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFU12 price difference to ZFZ12 is -0.28120211. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFZ12 Open price on 2012-11-30 is 124.7656. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFH13 Open price on 2012-11-30 is 124.6406. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFZ12 price difference to ZFH13 is -0.12499789. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFH13 Open price on 2013-02-28 is 124.3125. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFM13 Open price on 2013-02-28 is 123.9063. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFH13 price difference to ZFM13 is -0.40619659. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFM13 Open price on 2013-05-31 is 123.1563. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFU13 Open price on 2013-05-31 is 122.6172. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFM13 price difference to ZFU13 is -0.53909725. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFU13 Open price on 2013-08-30 is 120.5547. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFZ13 Open price on 2013-08-30 is 119.6328. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFU13 price difference to ZFZ13 is -0.92190278. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFZ13 Open price on 2013-11-29 is 121.7422. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFH14 Open price on 2013-11-29 is 120.8594. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: ZFZ13 price difference to ZFH14 is -0.88280213. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFH11 is -6.734395. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFM11 is -5.8202949. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFU11 is -4.7499952. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFZ11 is -3.8202958. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFH12 is -3.4608989. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFM12 is -3.3436966. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFU12 is -3.1561985. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFZ12 is -2.8749967. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFH13 is -2.7499986. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFM13 is -2.343802. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFU13 is -1.8047049. | 2014-02-10 07:08:19 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFZ13 is -0.88280213. | 2014-02-10 07:08:19 Cannot import symbols. File does not exist: C:\SierraChart\Data\HsampleQuoteBoard.SymbolList | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: FCEG4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: NSEA-MH4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: ARA-MH4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: CT-MH4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: OJ-MH4 | 2014-02-10 07:08:20 Cannot import symbols. File does not exist: C:\SierraChart\Data\HsampleQuoteBoard.SymbolList | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: RLM-MH4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: RLM-MH4 | 2014-02-10 07:08:20 Date rule based rollover from RLM-MH3 to next contract occurs at 2013-03-07 | 2014-02-10 07:08:20 Date rule based rollover from RLM-MM3 to next contract occurs at 2013-06-13 | 2014-02-10 07:08:20 Date rule based rollover from RLM-MU3 to next contract occurs at 2013-09-12 | 2014-02-10 07:08:20 Date rule based rollover from RLM-MZ3 to next contract occurs at 2013-12-12 | 2014-02-10 07:08:20 Date rule based rollover from RLM-MH4 to next contract occurs at 2014-03-13 | 2014-02-10 07:08:20 Checking Intraday data file for symbol RLM-MH3 for the date range from 2012-12-13 to 2013-03-07 | 2014-02-10 07:08:20 Checking Daily data file for symbol RLM-MH3 for the date range from 2012-12-13 to 2013-03-02 | 2014-02-10 07:08:20 Checking Intraday data file for symbol RLM-MM3 for the date range from 2013-03-07 to 2013-06-13 | 2014-02-10 07:08:20 Checking Daily data file for symbol RLM-MM3 for the date range from 2013-03-07 to 2013-06-08 | 2014-02-10 07:08:20 Checking Intraday data file for symbol RLM-MU3 for the date range from 2013-06-13 to 2013-09-12 | 2014-02-10 07:08:20 Checking Daily data file for symbol RLM-MU3 for the date range from 2013-06-13 to 2013-09-07 | 2014-02-10 07:08:20 Checking Intraday data file for symbol RLM-MZ3 for the date range from 2013-09-12 to 2013-12-12 | 2014-02-10 07:08:20 Checking Daily data file for symbol RLM-MZ3 for the date range from 2013-09-12 to 2013-12-07 | 2014-02-10 07:08:20 Checking Intraday data file for symbol RLM-MH4 for the date range from 2013-12-12 to 0 | 2014-02-10 07:08:20 Checking Daily data file for symbol RLM-MH4 for the date range from 2013-12-12 to 0 | 2014-02-10 07:08:20 Symbols used for RLM-MH4 continuous contract chart: | 2014-02-10 07:08:20 RLM-MH3 | 2014-02-10 07:08:20 RLM-MM3 | 2014-02-10 07:08:20 RLM-MU3 | 2014-02-10 07:08:20 RLM-MZ3 | 2014-02-10 07:08:20 RLM-MH4 | 2014-02-10 07:08:20 Volume based rollover from RLM-MH3 to RLM-MM3 occurs at 2013-03-08 | 2014-02-10 07:08:20 Volume based rollover from RLM-MM3 to RLM-MU3 occurs at 2013-06-14 | 2014-02-10 07:08:20 Volume based rollover from RLM-MU3 to RLM-MZ3 occurs at 2013-09-13 | 2014-02-10 07:08:20 Volume based rollover from RLM-MZ3 to RLM-MH4 occurs at 2013-12-13 | 2014-02-10 07:08:20 RLM-MH4 [CBV] 30 Min #3: Performing continuous futures contract back adjustment calculations. | 2014-02-10 07:08:20 RLM-MH4 [CBV] 30 Min #3: RLM-MH3 Open price on 2013-03-08 is 933.6. | 2014-02-10 07:08:20 RLM-MH4 [CBV] 30 Min #3: RLM-MM3 Open price on 2013-03-08 is 930.2. | 2014-02-10 07:08:20 RLM-MH4 [CBV] 30 Min #3: RLM-MH3 price difference to RLM-MM3 is -3.3999877. | 2014-02-10 07:08:20 RLM-MH4 [CBV] 30 Min #3: RLM-MM3 Open price on 2013-06-14 is 990.1. | 2014-02-10 07:08:20 RLM-MH4 [CBV] 30 Min #3: RLM-MU3 Open price on 2013-06-14 is 987.3. | 2014-02-10 07:08:20 RLM-MH4 [CBV] 30 Min #3: RLM-MM3 price difference to RLM-MU3 is -2.8000121. | 2014-02-10 07:08:20 RLM-MH4 [CBV] 30 Min #3: RLM-MU3 Open price on 2013-09-13 is 1050.7. | 2014-02-10 07:08:20 RLM-MH4 [CBV] 30 Min #3: RLM-MZ3 Open price on 2013-09-13 is 1046.7. | 2014-02-10 07:08:20 RLM-MH4 [CBV] 30 Min #3: RLM-MU3 price difference to RLM-MZ3 is -4.0000486. | 2014-02-10 07:08:20 RLM-MH4 [CBV] 30 Min #3: RLM-MZ3 Open price on 2013-12-13 is 1101.6. | 2014-02-10 07:08:20 RLM-MH4 [CBV] 30 Min #3: RLM-MH4 Open price on 2013-12-13 is 1098.5. | 2014-02-10 07:08:20 RLM-MH4 [CBV] 30 Min #3: RLM-MZ3 price difference to RLM-MH4 is -3.0999999. | 2014-02-10 07:08:20 RLM-MH4 [CBV] 30 Min #3: Back adjust amount for symbol RLM-MH3 is -13.300049. | 2014-02-10 07:08:20 RLM-MH4 [CBV] 30 Min #3: Back adjust amount for symbol RLM-MM3 is -9.9000607. | 2014-02-10 07:08:20 RLM-MH4 [CBV] 30 Min #3: Back adjust amount for symbol RLM-MU3 is -7.1000485. | 2014-02-10 07:08:20 RLM-MH4 [CBV] 30 Min #3: Back adjust amount for symbol RLM-MZ3 is -3.0999999. | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: GLTLH4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: STERLH4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: EURCHFH4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: ZQG4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: FEU3H4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: ZYGG4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: WTI-MH4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: QGG4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: XCH4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: ZEH4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: MWEH4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: KEH4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: XBH4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: XWH4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: ZRH4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: RS2-MH4 | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: WSGH4 | 2014-02-10 07:08:20 HD Request # 2 - Downloading Historical Daily chart data for ZFH14. Starting date: 2014-02-07. Service: oec | 2014-02-10 07:08:20 HD Request # 2 - Requesting historical Daily data for ZFH14 starting at 2014-02-06 | 2014-02-10 07:08:20 HD Request # 3 - Downloading Intraday chart data for ZFH4 to the file ZFH4.scid. Service: oec | 2014-02-10 07:08:20 HD Request # 3 - Download start Date-Time: 2014-02-10 07:05:36.0 | 2014-02-10 07:08:20 HD Request # 3 - Using server: ds3.sierracharts.com port 80 | 2014-02-10 07:08:20 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-02-10 07:08:20 The network socket is connected. | 2014-02-10 07:08:20 HD Request # 3 - Sending historical data logon request message. | 2014-02-10 07:08:20 No SC real-time data feed mapping found for symbol: RLM-MH4 | 2014-02-10 07:08:20 HD Request # 2 - Receiving historical Daily data for ZFH14 starting at 2014-02-06 | 2014-02-10 07:08:20 Writing historical Daily data for ZFH14 to the file ZFH14.dly | 2014-02-10 07:08:20 HD Request # 2 - Received 3 records from 2014-02-06 00:00:00 to 2014-02-10 00:00:00 (5.0 days) and wrote 2 records for ZFH14 | 2014-02-10 07:08:20 HD Request # 2 - Daily download COMPLETE for ZFH14 | 2014-02-10 07:08:20 Date rule based rollover from ZFH11 to next contract occurs at 2011-02-24 | 2014-02-10 07:08:20 Date rule based rollover from ZFM11 to next contract occurs at 2011-05-27 | 2014-02-10 07:08:20 Date rule based rollover from ZFU11 to next contract occurs at 2011-08-29 | 2014-02-10 07:08:20 Date rule based rollover from ZFZ11 to next contract occurs at 2011-11-28 | 2014-02-10 07:08:20 Date rule based rollover from ZFH12 to next contract occurs at 2012-02-27 | 2014-02-10 07:08:20 Date rule based rollover from ZFM12 to next contract occurs at 2012-05-29 | 2014-02-10 07:08:20 Date rule based rollover from ZFU12 to next contract occurs at 2012-08-29 | 2014-02-10 07:08:20 Date rule based rollover from ZFZ12 to next contract occurs at 2012-11-28 | 2014-02-10 07:08:20 Date rule based rollover from ZFH13 to next contract occurs at 2013-02-26 | 2014-02-10 07:08:20 Date rule based rollover from ZFM13 to next contract occurs at 2013-05-29 | 2014-02-10 07:08:20 Date rule based rollover from ZFU13 to next contract occurs at 2013-08-28 | 2014-02-10 07:08:20 Date rule based rollover from ZFZ13 to next contract occurs at 2013-11-27 | 2014-02-10 07:08:20 Date rule based rollover from ZFH14 to next contract occurs at 2014-02-26 | 2014-02-10 07:08:20 Checking Daily data file for symbol ZFH11 for the date range from 2010-11-26 to 2011-02-19 | 2014-02-10 07:08:20 Checking Daily data file for symbol ZFM11 for the date range from 2011-02-24 to 2011-05-22 | 2014-02-10 07:08:20 Checking Daily data file for symbol ZFU11 for the date range from 2011-05-27 to 2011-08-24 | 2014-02-10 07:08:20 Checking Daily data file for symbol ZFZ11 for the date range from 2011-08-29 to 2011-11-23 | 2014-02-10 07:08:20 Checking Daily data file for symbol ZFH12 for the date range from 2011-11-28 to 2012-02-22 | 2014-02-10 07:08:20 Checking Daily data file for symbol ZFM12 for the date range from 2012-02-27 to 2012-05-24 | 2014-02-10 07:08:20 Checking Daily data file for symbol ZFU12 for the date range from 2012-05-29 to 2012-08-24 | 2014-02-10 07:08:20 Checking Daily data file for symbol ZFZ12 for the date range from 2012-08-29 to 2012-11-23 | 2014-02-10 07:08:20 Checking Daily data file for symbol ZFH13 for the date range from 2012-11-28 to 2013-02-21 | 2014-02-10 07:08:20 Checking Daily data file for symbol ZFM13 for the date range from 2013-02-26 to 2013-05-24 | 2014-02-10 07:08:20 Checking Daily data file for symbol ZFU13 for the date range from 2013-05-29 to 2013-08-23 | 2014-02-10 07:08:20 Checking Daily data file for symbol ZFZ13 for the date range from 2013-08-28 to 2013-11-22 | 2014-02-10 07:08:20 Checking Daily data file for symbol ZFH14 for the date range from 2013-11-27 to 0 | 2014-02-10 07:08:20 Symbols used for ZFH14 continuous contract chart: | 2014-02-10 07:08:20 ZFH11 | 2014-02-10 07:08:20 ZFM11 | 2014-02-10 07:08:20 ZFU11 | 2014-02-10 07:08:20 ZFZ11 | 2014-02-10 07:08:20 ZFH12 | 2014-02-10 07:08:20 ZFM12 | 2014-02-10 07:08:20 ZFU12 | 2014-02-10 07:08:20 ZFZ12 | 2014-02-10 07:08:20 ZFH13 | 2014-02-10 07:08:20 ZFM13 | 2014-02-10 07:08:20 ZFU13 | 2014-02-10 07:08:20 ZFZ13 | 2014-02-10 07:08:20 ZFH14 | 2014-02-10 07:08:20 Volume based rollover from ZFH11 to ZFM11 occurs at 2011-02-28 | 2014-02-10 07:08:20 Volume based rollover from ZFM11 to ZFU11 occurs at 2011-05-31 | 2014-02-10 07:08:20 Volume based rollover from ZFU11 to ZFZ11 occurs at 2011-08-31 | 2014-02-10 07:08:20 Volume based rollover from ZFZ11 to ZFH12 occurs at 2011-11-30 | 2014-02-10 07:08:20 Volume based rollover from ZFH12 to ZFM12 occurs at 2012-02-29 | 2014-02-10 07:08:20 Volume based rollover from ZFM12 to ZFU12 occurs at 2012-05-31 | 2014-02-10 07:08:21 Volume based rollover from ZFU12 to ZFZ12 occurs at 2012-08-31 | 2014-02-10 07:08:21 Volume based rollover from ZFZ12 to ZFH13 occurs at 2012-11-30 | 2014-02-10 07:08:21 Volume based rollover from ZFH13 to ZFM13 occurs at 2013-02-28 | 2014-02-10 07:08:21 Volume based rollover from ZFM13 to ZFU13 occurs at 2013-05-31 | 2014-02-10 07:08:21 Volume based rollover from ZFU13 to ZFZ13 occurs at 2013-08-30 | 2014-02-10 07:08:21 Volume based rollover from ZFZ13 to ZFH14 occurs at 2013-11-29 | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: Performing continuous futures contract back adjustment calculations. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFH11 Open price on 2011-02-28 is 117.7266. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFM11 Open price on 2011-02-28 is 116.8125. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFH11 price difference to ZFM11 is -0.91409999. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFM11 Open price on 2011-05-31 is 120.1953. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFU11 Open price on 2011-05-31 is 119.125. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFM11 price difference to ZFU11 is -1.0703. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFU11 Open price on 2011-08-31 is 123.5938. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFZ11 Open price on 2011-08-31 is 122.6641. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFU11 price difference to ZFZ11 is -0.92969936. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFZ11 Open price on 2011-11-30 is 123.1016. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFH12 Open price on 2011-11-30 is 122.7422. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFZ11 price difference to ZFH12 is -0.35939723. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFH12 Open price on 2012-02-29 is 123.4766. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFM12 Open price on 2012-02-29 is 123.3594. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFH12 price difference to ZFM12 is -0.11720211. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFM12 Open price on 2012-05-31 is 124.3281. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFU12 Open price on 2012-05-31 is 124.1406. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFM12 price difference to ZFU12 is -0.18749788. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFU12 Open price on 2012-08-31 is 124.6406. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFZ12 Open price on 2012-08-31 is 124.3594. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFU12 price difference to ZFZ12 is -0.28120211. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFZ12 Open price on 2012-11-30 is 124.7656. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFH13 Open price on 2012-11-30 is 124.6406. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFZ12 price difference to ZFH13 is -0.12499789. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFH13 Open price on 2013-02-28 is 124.3125. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFM13 Open price on 2013-02-28 is 123.9063. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFH13 price difference to ZFM13 is -0.40619659. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFM13 Open price on 2013-05-31 is 123.1563. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFU13 Open price on 2013-05-31 is 122.6172. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFM13 price difference to ZFU13 is -0.53909725. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFU13 Open price on 2013-08-30 is 120.5547. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFZ13 Open price on 2013-08-30 is 119.6328. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFU13 price difference to ZFZ13 is -0.92190278. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFZ13 Open price on 2013-11-29 is 121.7422. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFH14 Open price on 2013-11-29 is 120.8594. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: ZFZ13 price difference to ZFH14 is -0.88280213. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFH11 is -6.734395. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFM11 is -5.8202949. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFU11 is -4.7499952. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFZ11 is -3.8202958. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFH12 is -3.4608989. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFM12 is -3.3436966. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFU12 is -3.1561985. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFZ12 is -2.8749967. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFH13 is -2.7499986. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFM13 is -2.343802. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFU13 is -1.8047049. | 2014-02-10 07:08:21 ZFH4 [CBV] Daily #1: Back adjust amount for symbol ZFZ13 is -0.88280213. | 2014-02-10 07:08:21 HD Request # 3 - Requesting up to 1095 days of Intraday data. Record interval: 1 | 2014-02-10 07:08:21 The network socket for historical data has been closed. | 2014-02-10 07:08:21 HD Request # 3 - Historical data for ZFH4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-02-10 07:08:21 HD Request # 3 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZFH4 | 2014-02-10 07:08:21 HD Request # 3 - Intraday download COMPLETE for ZFH4 | 2014-02-10 07:08:21 HD Request # 4 - Downloading Intraday chart data for RLM-MH4 to the file RLM-MH4.scid. Service: oec | 2014-02-10 07:08:21 HD Request # 4 - Download start Date-Time: 2014-02-10 07:05:44.0 | 2014-02-10 07:08:21 HD Request # 4 - Using server: ds5.sierracharts.com port 80 | 2014-02-10 07:08:21 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-02-10 07:08:21 The network socket is connected. | 2014-02-10 07:08:21 HD Request # 4 - Sending historical data logon request message. | 2014-02-10 07:08:21 HD Request # 4 - Requesting up to 1095 days of Intraday data. Record interval: 1 | 2014-02-10 07:08:21 The network socket for historical data has been closed. | 2014-02-10 07:08:21 HD Request # 4 - Historical data for RLM-MH4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-02-10 07:08:21 HD Request # 4 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for RLM-MH4 | 2014-02-10 07:08:21 HD Request # 4 - Intraday download COMPLETE for RLM-MH4 | 2014-02-10 07:08:21 Open E Cry FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-02-10 07:08:22 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-02-10 07:08:22 The network socket is connected. | 2014-02-10 07:08:22 The socket starting SSL connection. | 2014-02-10 07:08:22 SSL socket is now connected. | 2014-02-10 07:08:22 OEC FIX Trading session: Sending the Logon message. | 2014-02-10 07:08:23 Open E Cry FIX/FAST: Connected to trading server. | 2014-02-10 07:08:23 Open E Cry FIX/FAST: Connecting to FAST market data server: prod.openecry.com:9301. | 2014-02-10 07:08:23 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-02-10 07:08:23 The network socket is connected. | 2014-02-10 07:08:23 OEC FAST Market Data session: Sending the Hello message. | 2014-02-10 07:08:23 OEC FAST Market Data session: Sending the Logon message. | 2014-02-10 07:08:23 Open E Cry FIX/FAST: Connected to the market data server. | 2014-02-10 07:08:23 Open E Cry FIX/FAST: Connected. | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: ESH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: NQH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: YMH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: ZCH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: ZMH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: KC-MH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: DX-MH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: DX-MH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: 6JH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: 6BH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: FGBMH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: FGBLH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: GHGH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: GGCJ4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: GCLH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: ZSH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: ZWH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: SB-MH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: FTSEH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: FTSEH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: CC-MH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: CC-MH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: RLM-MH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: RLM-MH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: RF-MH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: NKDH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: NIYH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: FCEG4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: FCEG4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: FDAXH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: FESXH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: F2MXH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: 6EH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: 6AH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: 6CH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: 6MH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: 6SH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: 6NH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: ZBH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: ZNH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: ZFH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: ZTH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: UBH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: FGBXH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: GLTLH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: GLTLH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: FGBSH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: STERLH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: STERLH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: EURCHFH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: EURCHFH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: ZQG4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: ZQG4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: FOATH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: FBTPH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: FEU3H4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: FEU3H4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: GSIH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: ZYGG4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: ZYGG4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: MGCG4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: GPAH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: GPLJ4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: GHOH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: NSEA-MH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: NSEA-MH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: ARA-MH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: ARA-MH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: WTI-MH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: WTI-MH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: QMH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: QGG4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: QGG4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: GNGH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: GRBH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: XCH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: XCH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: ZEH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: ZEH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: MWEH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: MWEH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: KEH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: KEH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: XBH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: XBH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: XWH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: XWH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: ZOH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: ZRH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: ZRH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: ZLH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: RS2-MH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: RS2-MH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: CT-MH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: CT-MH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: LBSH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: DAH4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: OJ-MH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: OJ-MH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: COF10H4 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: WSGH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: WSGH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: GFH4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: HEJ4 | 2014-02-10 07:08:23 Open E Cry FIX/FAST - Starting real-time market data updates for: LEJ4 | 2014-02-10 07:08:23 Symbol Error - KC-MH4 is unknown, unavailable, or improperly formatted. FIX reject reason: Your subscription limit of 5 has been reached | 2014-02-10 07:08:23 HD Request # 5 - Downloading Intraday chart data for ZFH4 to the file ZFH4.scid. Service: oec | 2014-02-10 07:08:23 HD Request # 5 - Download start Date-Time: 2014-02-10 07:05:36.0 | 2014-02-10 07:08:23 HD Request # 5 - Using server: ds3.sierracharts.com port 80 | 2014-02-10 07:08:23 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-02-10 07:08:23 QuoteDateTime (00:00:00) in UpdateBidAsk is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2014-02-10 07:08:23 QuoteDateTime (00:00:00) in UpdateBidAsk is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2014-02-10 07:08:23 The network socket is connected. | 2014-02-10 07:08:23 HD Request # 5 - Sending historical data logon request message. | 2014-02-10 07:08:23 HD Request # 5 - Requesting up to 1095 days of Intraday data. Record interval: 1 | 2014-02-10 07:08:23 No SC real-time data feed mapping found for symbol: RLM-MH4 | 2014-02-10 07:08:23 HD Request # 5 - Decompressing data. | 2014-02-10 07:08:24 HD Request # 5 - Receiving Intraday data for ZFH4 starting at 2014-02-10 07:05:36 | 2014-02-10 07:08:24 HD Request # 5 - Timestamp of first Intraday data file record written: 2014-02-10 07:05:36 | 2014-02-10 07:08:24 The network socket for historical data has been closed. | 2014-02-10 07:08:24 HD Request # 5 - Received 15 records from 2014-02-10 07:05:36 to 2014-02-10 07:08:08 (2.5 minutes) and wrote 15 records for ZFH4 | 2014-02-10 07:08:24 HD Request # 5 - Intraday download COMPLETE for ZFH4 | 2014-02-10 07:08:24 Real-time Intraday chart data file updates started for ZFH4 | 2014-02-10 07:08:24 HD Request # 6 - Downloading Intraday chart data for RLM-MH4 to the file RLM-MH4.scid. Service: oec | 2014-02-10 07:08:24 HD Request # 6 - Download start Date-Time: 2014-02-10 07:05:44.0 | 2014-02-10 07:08:24 HD Request # 6 - Using server: ds5.sierracharts.com port 80 | 2014-02-10 07:08:24 Symbol Error - QGG4 is unknown, unavailable, or improperly formatted. FIX reject reason: Unknown contract | 2014-02-10 07:08:24 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-02-10 07:08:24 Symbol Error - QGG4 is unknown, unavailable, or improperly formatted. FIX reject reason: Unknown contract | 2014-02-10 07:08:24 The network socket is connected. | 2014-02-10 07:08:24 HD Request # 6 - Sending historical data logon request message. | 2014-02-10 07:08:24 HD Request # 6 - Requesting up to 1095 days of Intraday data. Record interval: 1 | 2014-02-10 07:08:24 HD Request # 6 - Decompressing data. | 2014-02-10 07:08:24 HD Request # 6 - Receiving Intraday data for RLM-MH4 starting at 2014-02-10 07:05:44 | 2014-02-10 07:08:24 HD Request # 6 - Timestamp of first Intraday data file record written: 2014-02-10 07:05:44 | 2014-02-10 07:08:24 The network socket for historical data has been closed. | 2014-02-10 07:08:24 HD Request # 6 - Received 120 records from 2014-02-10 07:05:44 to 2014-02-10 07:08:20 (2.6 minutes) and wrote 120 records for RLM-MH4 | 2014-02-10 07:08:24 HD Request # 6 - Intraday download COMPLETE for RLM-MH4 | 2014-02-10 07:08:24 Real-time Intraday chart data file updates started for RLM-MH4 | 2014-02-10 07:08:24 File >> Disconnect selected. | 2014-02-10 07:08:45 OEC FIX Trading session: Sending a Logout message. | 2014-02-10 07:08:45 OEC FAST Market Data session: Sending a Logout message. | 2014-02-10 07:08:45 Disconnected from Open E Cry. | 2014-02-10 07:08:45 OEC FIX Trading session: Received a Logout message. | 2014-02-10 07:08:45 The SSL socket was shut down successfully. | 2014-02-10 07:08:45 OEC FIX Trading session: Logged out and disconnected. | 2014-02-10 07:08:45 Disconnected from the Open E Cry FIX Orders server. | 2014-02-10 07:08:45 Socket closed. No error. | 2014-02-10 07:08:46 OEC FAST Market Data session: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2014-02-10 07:08:46 Open E Cry FIX/FAST: Disconnected from the market data server. | 2014-02-10 07:08:46 Open E Cry FIX/FAST: Disconnected. | 2014-02-10 07:08:46 Open E Cry FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-02-10 07:08:46 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-02-10 07:08:46 The network socket is connected. | 2014-02-10 07:08:46 The socket starting SSL connection. | 2014-02-10 07:08:46 SSL socket is now connected. | 2014-02-10 07:08:47 OEC FIX Trading session: Sending the Logon message. | 2014-02-10 07:08:47 Open E Cry FIX/FAST: Connected to trading server. | 2014-02-10 07:08:47 Open E Cry FIX/FAST: Connecting to FAST market data server: prod.openecry.com:9301. | 2014-02-10 07:08:47 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-02-10 07:08:47 The network socket is connected. | 2014-02-10 07:08:47 OEC FAST Market Data session: Sending the Hello message. | 2014-02-10 07:08:47 OEC FAST Market Data session: Sending the Logon message. | 2014-02-10 07:08:47 Open E Cry FIX/FAST: Connected to the market data server. | 2014-02-10 07:08:47 Open E Cry FIX/FAST: Connected. | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: ESH4 | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: NQH4 | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: YMH4 | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: ZCH4 | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: ZMH4 | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: KC-MH4 | 2014-02-10 07:08:47 No SC real-time data feed mapping found for symbol: DX-MH4 | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: DX-MH4 | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: 6JH4 | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: 6BH4 | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: FGBMH4 | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: FGBLH4 | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: GHGH4 | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: GGCJ4 | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: GCLH4 | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: ZSH4 | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: ZWH4 | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: SB-MH4 | 2014-02-10 07:08:47 No SC real-time data feed mapping found for symbol: FTSEH4 | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: FTSEH4 | 2014-02-10 07:08:47 No SC real-time data feed mapping found for symbol: CC-MH4 | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: CC-MH4 | 2014-02-10 07:08:47 No SC real-time data feed mapping found for symbol: RLM-MH4 | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: RLM-MH4 | 2014-02-10 07:08:47 Open E Cry FIX/FAST - Starting real-time market data updates for: ZFH4 | 2014-02-10 07:08:47 HD Request # 7 - Downloading Intraday chart data for ZFH4 to the file ZFH4.scid. Service: oec | 2014-02-10 07:08:47 HD Request # 7 - Download start Date-Time: 2014-02-10 07:08:08.0 | 2014-02-10 07:08:47 HD Request # 7 - Using server: ds3.sierracharts.com port 80 | 2014-02-10 07:08:47 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-02-10 07:08:47 The network socket is connected. | 2014-02-10 07:08:48 HD Request # 7 - Sending historical data logon request message. | 2014-02-10 07:08:48 Symbol Error - KC-MH4 is unknown, unavailable, or improperly formatted. FIX reject reason: Your subscription limit of 5 has been reached | 2014-02-10 07:08:48 HD Request # 7 - Requesting up to 1095 days of Intraday data. Record interval: 1 | 2014-02-10 07:08:48 HD Request # 7 - Decompressing data. | 2014-02-10 07:08:48 HD Request # 7 - Receiving Intraday data for ZFH4 starting at 2014-02-10 07:08:08 | 2014-02-10 07:08:48 HD Request # 7 - Timestamp of first Intraday data file record written: 2014-02-10 07:08:08 | 2014-02-10 07:08:48 The network socket for historical data has been closed. | 2014-02-10 07:08:48 HD Request # 7 - Received 4 records from 2014-02-10 07:08:08 to 2014-02-10 07:08:44 (36.0 seconds) and wrote 4 records for ZFH4 | 2014-02-10 07:08:48 HD Request # 7 - Intraday download COMPLETE for ZFH4 | 2014-02-10 07:08:48 Real-time Intraday chart data file updates started for ZFH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: RLM-MH4 | 2014-02-10 07:08:48 HD Request # 8 - Downloading Intraday chart data for RLM-MH4 to the file RLM-MH4.scid. Service: oec | 2014-02-10 07:08:48 HD Request # 8 - Download start Date-Time: 2014-02-10 07:08:20.0 | 2014-02-10 07:08:48 HD Request # 8 - Using server: ds5.sierracharts.com port 80 | 2014-02-10 07:08:48 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: NKDH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: NIYH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: FCEG4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: FCEG4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: 6NH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: ZNH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: FGBSH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: FOATH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: GHOH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: NSEA-MH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: NSEA-MH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: ARA-MH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: ARA-MH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: CT-MH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: CT-MH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: OJ-MH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: OJ-MH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: GFH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: HEJ4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: LEJ4 | 2014-02-10 07:08:48 The network socket is connected. | 2014-02-10 07:08:48 HD Request # 8 - Sending historical data logon request message. | 2014-02-10 07:08:48 HD Request # 8 - Requesting up to 1095 days of Intraday data. Record interval: 1 | 2014-02-10 07:08:48 HD Request # 8 - Decompressing data. | 2014-02-10 07:08:48 HD Request # 8 - Receiving Intraday data for RLM-MH4 starting at 2014-02-10 07:08:20 | 2014-02-10 07:08:48 HD Request # 8 - Timestamp of first Intraday data file record written: 2014-02-10 07:08:20 | 2014-02-10 07:08:48 The network socket for historical data has been closed. | 2014-02-10 07:08:48 HD Request # 8 - Received 18 records from 2014-02-10 07:08:20 to 2014-02-10 07:08:43 (23.0 seconds) and wrote 18 records for RLM-MH4 | 2014-02-10 07:08:48 HD Request # 8 - Intraday download COMPLETE for RLM-MH4 | 2014-02-10 07:08:48 Real-time Intraday chart data file updates started for RLM-MH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: RF-MH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: FDAXH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: FESXH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: F2MXH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: 6EH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: 6AH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: 6CH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: 6MH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: 6SH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: ZBH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: ZTH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: UBH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: FGBXH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: GLTLH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: GLTLH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: STERLH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: STERLH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: EURCHFH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: EURCHFH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: ZQG4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: ZQG4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: FBTPH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: FEU3H4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: FEU3H4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: GSIH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: ZYGG4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: ZYGG4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: MGCG4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: GPAH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: GPLJ4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: WTI-MH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: WTI-MH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: QMH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: QGG4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: QGG4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: GNGH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: GRBH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: XCH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: XCH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: ZEH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: ZEH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: MWEH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: MWEH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: KEH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: KEH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: XBH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: XBH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: XWH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: XWH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: ZOH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: ZRH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: ZRH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: ZLH4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: RS2-MH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: RS2-MH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: LBSH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: DAH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: COF10H4 | 2014-02-10 07:08:48 No SC real-time data feed mapping found for symbol: WSGH4 | 2014-02-10 07:08:48 Open E Cry FIX/FAST - Starting real-time market data updates for: WSGH4 | 2014-02-10 07:08:48 QuoteDateTime (00:00:00) in UpdateBidAsk is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2014-02-10 07:08:49 QuoteDateTime (00:00:00) in UpdateBidAsk is earlier than EARLIEST_REALTIME_DATE_TIME (2012-06-01 00:00:00). | 2014-02-10 07:08:49 Symbol Error - QGG4 is unknown, unavailable, or improperly formatted. FIX reject reason: Unknown contract | 2014-02-10 07:08:49 Symbol Error - QGG4 is unknown, unavailable, or improperly formatted. FIX reject reason: Unknown contract | 2014-02-10 07:08:49 Current selected Data/Trading service: Open E Cry FIX/FAST | 2014-02-10 07:14:43 Downloading Remote Assistance file.... | 2014-02-10 07:14:56 Download is complete, starting Remote Assistance. | 2014-02-10 07:15:00 Socket closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2014-02-10 07:16:51 The SSL socket was shut down successfully. | 2014-02-10 07:16:51 OEC FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2014-02-10 07:16:51 Connection to the external service has been lost. | 2014-02-10 07:16:51 OEC FAST Market Data session: Sending a Logout message. | 2014-02-10 07:16:51 Disconnected from Open E Cry. | 2014-02-10 07:16:51 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-10 07:16:51 Socket closed. No error. | 2014-02-10 07:16:51 OEC FAST Market Data session: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2014-02-10 07:16:51 Open E Cry FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-02-10 07:16:53 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-02-10 07:16:53 The network socket is connected. | 2014-02-10 07:16:53 The socket starting SSL connection. | 2014-02-10 07:16:53 SSL socket is now connected. | 2014-02-10 07:16:53 OEC FIX Trading session: Sending the Logon message. | 2014-02-10 07:16:54 Open E Cry FIX/FAST: Connected to trading server. | 2014-02-10 07:16:54 Open E Cry FIX/FAST: Connecting to FAST market data server: prod.openecry.com:9301. | 2014-02-10 07:16:54 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-02-10 07:16:54 The network socket is connected. | 2014-02-10 07:16:58 OEC FAST Market Data session: Sending the Hello message. | 2014-02-10 07:16:58 OEC FAST Market Data session: Sending the Logon message. | 2014-02-10 07:16:58 Open E Cry FIX/FAST: Connected to the market data server. | 2014-02-10 07:16:58 Open E Cry FIX/FAST: Connected. | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: ESH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: NQH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: YMH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: ZCH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: ZMH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: KC-MH4 | 2014-02-10 07:16:58 No SC real-time data feed mapping found for symbol: DX-MH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: DX-MH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: 6JH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: 6BH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: FGBMH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: FGBLH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: GHGH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: GGCJ4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: GCLH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: ZSH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: ZWH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: SB-MH4 | 2014-02-10 07:16:58 No SC real-time data feed mapping found for symbol: FTSEH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: FTSEH4 | 2014-02-10 07:16:58 No SC real-time data feed mapping found for symbol: CC-MH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: CC-MH4 | 2014-02-10 07:16:58 No SC real-time data feed mapping found for symbol: RLM-MH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: RLM-MH4 | 2014-02-10 07:16:58 No SC real-time data feed mapping found for symbol: RLM-MH4 | 2014-02-10 07:16:58 HD Request # 9 - Downloading Intraday chart data for RLM-MH4 to the file RLM-MH4.scid. Service: oec | 2014-02-10 07:16:58 HD Request # 9 - Download start Date-Time: 2014-02-10 07:08:43.0 | 2014-02-10 07:16:58 HD Request # 9 - Using server: ds3.sierracharts.com port 80 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: ZFH4 | 2014-02-10 07:16:58 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: NKDH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: NIYH4 | 2014-02-10 07:16:58 No SC real-time data feed mapping found for symbol: FCEG4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: FCEG4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: 6NH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: ZNH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: FGBSH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: FOATH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: GHOH4 | 2014-02-10 07:16:58 No SC real-time data feed mapping found for symbol: NSEA-MH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: NSEA-MH4 | 2014-02-10 07:16:58 No SC real-time data feed mapping found for symbol: ARA-MH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: ARA-MH4 | 2014-02-10 07:16:58 No SC real-time data feed mapping found for symbol: CT-MH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: CT-MH4 | 2014-02-10 07:16:58 No SC real-time data feed mapping found for symbol: OJ-MH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: OJ-MH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: GFH4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: HEJ4 | 2014-02-10 07:16:58 Open E Cry FIX/FAST - Starting real-time market data updates for: LEJ4 | 2014-02-10 07:16:58 Symbol Error - KC-MH4 is unknown, unavailable, or improperly formatted. FIX reject reason: Your subscription limit of 5 has been reached | 2014-02-10 07:16:58 The network socket is connected. | 2014-02-10 07:16:58 HD Request # 9 - Sending historical data logon request message. | 2014-02-10 07:16:58 HD Request # 9 - Requesting up to 1095 days of Intraday data. Record interval: 1 | 2014-02-10 07:16:58 HD Request # 9 - Decompressing data. | 2014-02-10 07:16:58 HD Request # 9 - Receiving Intraday data for RLM-MH4 starting at 2014-02-10 07:08:43 | 2014-02-10 07:16:58 HD Request # 9 - Timestamp of first Intraday data file record written: 2014-02-10 07:08:43 | 2014-02-10 07:16:58 The network socket for historical data has been closed. | 2014-02-10 07:16:58 HD Request # 9 - Received 378 records from 2014-02-10 07:08:43 to 2014-02-10 07:16:52 (8.1 minutes) and wrote 378 records for RLM-MH4 | 2014-02-10 07:16:58 HD Request # 9 - Intraday download COMPLETE for RLM-MH4 | 2014-02-10 07:16:58 Real-time Intraday chart data file updates started for RLM-MH4 | 2014-02-10 07:16:58 HD Request # 10 - Downloading Intraday chart data for ZFH4 to the file ZFH4.scid. Service: oec | 2014-02-10 07:16:58 HD Request # 10 - Download start Date-Time: 2014-02-10 07:08:44.0 | 2014-02-10 07:16:58 HD Request # 10 - Using server: ds5.sierracharts.com port 80 | 2014-02-10 07:16:58 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-02-10 |
[2014-02-10 16:47:22] |
This log shows you are going well over the 5 symbol OEC symbol limit. Keep in mind symbols on a Quote Board also count towards the symbol limit as well as charts. You will need to reduce the number of symbols and reconnect to the data feed as explained here: http://www.sierrachart.com/index.php?l=doc/openecry.php#Symbols Close all of your charts, and reduce the number of symbols on a Quote Board to less than 5. You need to open charts for less than 5 symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-10 16:48:25
[2014-02-10 18:33:53] |
User79157 - Posts: 22 |
im not aware of the symbols limit, but my partner here 5 feet away from me does not have the problem. We will do some testing, maybe it is a bandwidth problem as they are updating with just me using the software.
[2014-02-10 18:36:18] |
From the Message Log, clearly you are going over the five symbol limit. That is the source of the problem.
[2014-02-11 16:25:44] |
I noticed that there are several symbols that I can delete to help with price lag, however, I read the last post and I do have real time and historical futures data fee. Here is where I am confused. How am I supposed to switch between markets using ONLY 5 symbols? are you saying that because my quote board has over 80, that these are running at the same time? I only have one chart open at any time, but I need to switch between charts. I just need to know the best way to do this. I prefer having a large quote board for the ease of switching charts and easily setting alerts. Is there a way to load these quote boards with less data?
[2014-02-11 16:37:44] |
Yes.With the way that Sierra Chart works with OEC data, you really have to contact OEC and have them increase your Symbol limit or use a different Trading service other than OEC. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-12 17:05:03] |
I upped my symbols with OEC but the prices still don't match. How reliable is your data if I buy from sierra? confused still, because The OEC platform has the correct prices, but Sierra prices only match when i disconnect/reconnect. This tells me its more of an issue of the two "shaking hands"
[2014-02-12 17:40:12] |
Could you be more descriptive about this "the prices still don't match". Is the problem that the charts are not updating in real time? The Sierra Chart Futures Data Feed is very reliable. Here is more information about it: https://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-12 17:44:30] |
Correct. The prices do not update in real time. Some are off by a few ticks, some more. Its not good. ONLY when i use the " disconnect/reconnect" prices will match exactly. |
[2014-02-12 17:51:05] |
Enable Window >>Status Bar , if it is not already enabled. On the Status Bar below the main menu what is the number that you see after "ST:"? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-12 17:54:32] |
35
[2014-02-12 18:06:15] |
Software version: 1090 | 2014-02-12 10:04:30 Usage end date: 2014-05-31 | 2014-02-12 10:04:30 Enabled for: Sierra Chart Historical Data Service. | 2014-02-12 10:04:30 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-02-12 10:04:30 Active service: Open E Cry FIX/FAST | 2014-02-12 10:04:30 Time Zone: -08:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-02-12 10:04:30 2014-02-12 10:04:30 Local computer clock time | 2014-02-12 10:04:30 2014-02-12 18:04:30 GMT time | 2014-02-12 10:04:30 2014-02-12 10:04:30 Time zone adjusted time | 2014-02-12 10:04:30 Time difference to server time: 7 seconds. | 2014-02-12 10:04:30 Program path: C:\SierraChart\ | 2014-02-12 10:04:30 Data Files path: C:\SierraChart\Data\ | 2014-02-12 10:04:30 OS Version Number: 6.1 | 2014-02-12 10:04:30 Checking for new symbol settings for oec | 2014-02-12 10:04:30 Symbol settings are up-to-date for oec | 2014-02-12 10:04:30 Date rule based rollover from ESH11 to next contract occurs at 2011-03-10 | 2014-02-12 10:04:33 Date rule based rollover from ESM11 to next contract occurs at 2011-06-09 | 2014-02-12 10:04:33 Date rule based rollover from ESU11 to next contract occurs at 2011-09-08 | 2014-02-12 10:04:33 Date rule based rollover from ESZ11 to next contract occurs at 2011-12-08 | 2014-02-12 10:04:33 Date rule based rollover from ESH12 to next contract occurs at 2012-03-08 | 2014-02-12 10:04:33 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07 | 2014-02-12 10:04:33 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13 | 2014-02-12 10:04:33 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13 | 2014-02-12 10:04:33 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07 | 2014-02-12 10:04:33 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13 | 2014-02-12 10:04:33 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12 | 2014-02-12 10:04:33 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12 | 2014-02-12 10:04:33 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13 | 2014-02-12 10:04:33 Checking Daily data file for symbol ESH11 for the date range from 2010-12-09 to 2011-03-05 | 2014-02-12 10:04:33 Checking Daily data file for symbol ESM11 for the date range from 2011-03-10 to 2011-06-04 | 2014-02-12 10:04:33 Checking Daily data file for symbol ESU11 for the date range from 2011-06-09 to 2011-09-03 | 2014-02-12 10:04:33 Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-03 | 2014-02-12 10:04:33 Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-03 | 2014-02-12 10:04:33 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-02 | 2014-02-12 10:04:33 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-08 | 2014-02-12 10:04:33 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-08 | 2014-02-12 10:04:33 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-02 | 2014-02-12 10:04:33 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-08 | 2014-02-12 10:04:33 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-07 | 2014-02-12 10:04:33 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-07 | 2014-02-12 10:04:33 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 0 | 2014-02-12 10:04:33 Symbols used for ESH14 continuous contract chart: | 2014-02-12 10:04:33 ESH11 | 2014-02-12 10:04:33 ESM11 | 2014-02-12 10:04:33 ESU11 | 2014-02-12 10:04:33 ESZ11 | 2014-02-12 10:04:33 ESH12 | 2014-02-12 10:04:33 ESM12 | 2014-02-12 10:04:33 ESU12 | 2014-02-12 10:04:33 ESZ12 | 2014-02-12 10:04:33 ESH13 | 2014-02-12 10:04:33 ESM13 | 2014-02-12 10:04:33 ESU13 | 2014-02-12 10:04:33 ESZ13 | 2014-02-12 10:04:33 ESH14 | 2014-02-12 10:04:33 Volume based rollover from ESH11 to ESM11 occurs at 2011-03-11 | 2014-02-12 10:04:33 Volume based rollover from ESM11 to ESU11 occurs at 2011-06-10 | 2014-02-12 10:04:33 Volume based rollover from ESU11 to ESZ11 occurs at 2011-09-09 | 2014-02-12 10:04:33 Volume based rollover from ESZ11 to ESH12 occurs at 2011-12-09 | 2014-02-12 10:04:33 Volume based rollover from ESH12 to ESM12 occurs at 2012-03-09 | 2014-02-12 10:04:33 Volume based rollover from ESM12 to ESU12 occurs at 2012-06-08 | 2014-02-12 10:04:33 Volume based rollover from ESU12 to ESZ12 occurs at 2012-09-14 | 2014-02-12 10:04:33 Volume based rollover from ESZ12 to ESH13 occurs at 2012-12-14 | 2014-02-12 10:04:33 Volume based rollover from ESH13 to ESM13 occurs at 2013-03-08 | 2014-02-12 10:04:33 Volume based rollover from ESM13 to ESU13 occurs at 2013-06-14 | 2014-02-12 10:04:33 Volume based rollover from ESU13 to ESZ13 occurs at 2013-09-13 | 2014-02-12 10:04:33 Volume based rollover from ESZ13 to ESH14 occurs at 2013-12-13 | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: Performing continuous futures contract back adjustment calculations. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESH11 Open price on 2011-03-11 is 1293.75. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESM11 Open price on 2011-03-11 is 1289. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESH11 price difference to ESM11 is -4.75. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESM11 Open price on 2011-06-10 is 1287.75. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESU11 Open price on 2011-06-10 is 1282.25. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESM11 price difference to ESU11 is -5.5. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESU11 Open price on 2011-09-09 is 1185.75. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESZ11 Open price on 2011-09-09 is 1180. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESU11 price difference to ESZ11 is -5.75. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESZ11 Open price on 2011-12-09 is 1235.5. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESH12 Open price on 2011-12-09 is 1229.75. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESZ11 price difference to ESH12 is -5.75. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESH12 Open price on 2012-03-09 is 1366.25. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESM12 Open price on 2012-03-09 is 1360.25. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESH12 price difference to ESM12 is -6. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESM12 Open price on 2012-06-08 is 1316.25. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESU12 Open price on 2012-06-08 is 1309.5. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESM12 price difference to ESU12 is -6.75. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESU12 Open price on 2012-09-14 is 1456.5. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESZ12 Open price on 2012-09-14 is 1450. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESU12 price difference to ESZ12 is -6.5. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESZ12 Open price on 2012-12-14 is 1416.75. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESH13 Open price on 2012-12-14 is 1410.5. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESZ12 price difference to ESH13 is -6.25. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESH13 Open price on 2013-03-08 is 1542.75. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESM13 Open price on 2013-03-08 is 1538. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESH13 price difference to ESM13 is -4.75. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESM13 Open price on 2013-06-14 is 1637.75. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESU13 Open price on 2013-06-14 is 1631.5. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESM13 price difference to ESU13 is -6.25. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESU13 Open price on 2013-09-13 is 1684.75. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESZ13 Open price on 2013-09-13 is 1678.25. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESU13 price difference to ESZ13 is -6.5. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESZ13 Open price on 2013-12-13 is 1773.5. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESH14 Open price on 2013-12-13 is 1767. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: ESZ13 price difference to ESH14 is -6.5. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESH11 is -71.25. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESM11 is -66.5. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESU11 is -61. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESZ11 is -55.25. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESH12 is -49.5. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESM12 is -43.5. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESU12 is -36.75. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESZ12 is -30.25. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESH13 is -24. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESM13 is -19.25. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESU13 is -13. | 2014-02-12 10:04:33 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESZ13 is -6.5. | 2014-02-12 10:04:33 No SC real-time data feed mapping found for symbol: RLM-MH4 | 2014-02-12 10:04:33 No SC real-time data feed mapping found for symbol: DX-MH4 | 2014-02-12 10:04:33 No SC real-time data feed mapping found for symbol: NSEA-MH4 | 2014-02-12 10:04:33 No SC real-time data feed mapping found for symbol: ARA-MH4 | 2014-02-12 10:04:33 No SC real-time data feed mapping found for symbol: WTI-MH4 | 2014-02-12 10:04:33 No SC real-time data feed mapping found for symbol: CC-MH4 | 2014-02-12 10:04:33 No SC real-time data feed mapping found for symbol: CT-MH4 | 2014-02-12 10:04:33 Date rule based rollover from ZWN3 to next contract occurs at 2013-06-26 | 2014-02-12 10:04:34 Date rule based rollover from ZWU3 to next contract occurs at 2013-08-28 | 2014-02-12 10:04:34 Date rule based rollover from ZWZ3 to next contract occurs at 2013-11-27 | 2014-02-12 10:04:34 Date rule based rollover from ZWH4 to next contract occurs at 2014-02-26 | 2014-02-12 10:04:34 Checking Intraday data file for symbol ZWN3 for the date range from 2013-04-26 to 2013-06-26 | 2014-02-12 10:04:34 Checking Daily data file for symbol ZWN3 for the date range from 2013-04-26 to 2013-06-21 | 2014-02-12 10:04:34 Checking Intraday data file for symbol ZWU3 for the date range from 2013-06-26 to 2013-08-28 | 2014-02-12 10:04:34 Checking Daily data file for symbol ZWU3 for the date range from 2013-06-26 to 2013-08-23 | 2014-02-12 10:04:34 Checking Intraday data file for symbol ZWZ3 for the date range from 2013-08-28 to 2013-11-27 | 2014-02-12 10:04:34 Checking Daily data file for symbol ZWZ3 for the date range from 2013-08-28 to 2013-11-22 | 2014-02-12 10:04:34 Checking Intraday data file for symbol ZWH4 for the date range from 2013-11-27 to 0 | 2014-02-12 10:04:34 Checking Daily data file for symbol ZWH4 for the date range from 2013-11-27 to 0 | 2014-02-12 10:04:34 Symbols used for ZWH4 continuous contract chart: | 2014-02-12 10:04:34 ZWN3 | 2014-02-12 10:04:34 ZWU3 | 2014-02-12 10:04:34 ZWZ3 | 2014-02-12 10:04:34 ZWH4 | 2014-02-12 10:04:34 Volume based rollover from ZWN3 to ZWU3 occurs at 2013-06-24 | 2014-02-12 10:04:34 Volume based rollover from ZWU3 to ZWZ3 occurs at 2013-08-07 | 2014-02-12 10:04:34 Volume based rollover from ZWZ3 to ZWH4 occurs at 2013-11-21 | 2014-02-12 10:04:34 HD Request # 2 - Downloading Historical Daily chart data for ESH14. Starting date: 2014-02-11. Service: oec | 2014-02-12 10:04:34 HD Request # 2 - Requesting historical Daily data for ESH14 starting at 2014-02-10 | 2014-02-12 10:04:34 HD Request # 3 - Downloading Intraday chart data for ESH4 to the file ESH4.scid. Service: oec | 2014-02-12 10:04:34 HD Request # 3 - Download start Date-Time: 2014-02-12 10:03:12.0 | 2014-02-12 10:04:34 HD Request # 3 - Using server: ds4.sierracharts.com port 80 | 2014-02-12 10:04:34 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-02-12 10:04:34 The network socket is connected. | 2014-02-12 10:04:34 HD Request # 3 - Sending historical data logon request message. | 2014-02-12 10:04:34 HD Request # 2 - Receiving historical Daily data for ESH14 starting at 2014-02-10 | 2014-02-12 10:04:34 Writing historical Daily data for ESH14 to the file ESH14.dly | 2014-02-12 10:04:34 HD Request # 2 - Received 3 records from 2014-02-10 00:00:00 to 2014-02-12 00:00:00 (3.0 days) and wrote 2 records for ESH14 | 2014-02-12 10:04:34 HD Request # 2 - Daily download COMPLETE for ESH14 | 2014-02-12 10:04:34 Date rule based rollover from ESH11 to next contract occurs at 2011-03-10 | 2014-02-12 10:04:34 Date rule based rollover from ESM11 to next contract occurs at 2011-06-09 | 2014-02-12 10:04:34 Date rule based rollover from ESU11 to next contract occurs at 2011-09-08 | 2014-02-12 10:04:34 Date rule based rollover from ESZ11 to next contract occurs at 2011-12-08 | 2014-02-12 10:04:34 Date rule based rollover from ESH12 to next contract occurs at 2012-03-08 | 2014-02-12 10:04:34 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07 | 2014-02-12 10:04:34 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13 | 2014-02-12 10:04:34 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13 | 2014-02-12 10:04:34 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07 | 2014-02-12 10:04:34 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13 | 2014-02-12 10:04:34 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12 | 2014-02-12 10:04:34 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12 | 2014-02-12 10:04:34 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13 | 2014-02-12 10:04:34 Checking Daily data file for symbol ESH11 for the date range from 2010-12-09 to 2011-03-05 | 2014-02-12 10:04:34 Checking Daily data file for symbol ESM11 for the date range from 2011-03-10 to 2011-06-04 | 2014-02-12 10:04:34 Checking Daily data file for symbol ESU11 for the date range from 2011-06-09 to 2011-09-03 | 2014-02-12 10:04:34 Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-03 | 2014-02-12 10:04:34 Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-03 | 2014-02-12 10:04:34 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-02 | 2014-02-12 10:04:34 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-08 | 2014-02-12 10:04:34 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-08 | 2014-02-12 10:04:34 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-02 | 2014-02-12 10:04:34 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-08 | 2014-02-12 10:04:35 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-07 | 2014-02-12 10:04:35 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-07 | 2014-02-12 10:04:35 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 0 | 2014-02-12 10:04:35 Symbols used for ESH14 continuous contract chart: | 2014-02-12 10:04:35 ESH11 | 2014-02-12 10:04:35 ESM11 | 2014-02-12 10:04:35 ESU11 | 2014-02-12 10:04:35 ESZ11 | 2014-02-12 10:04:35 ESH12 | 2014-02-12 10:04:35 ESM12 | 2014-02-12 10:04:35 ESU12 | 2014-02-12 10:04:35 ESZ12 | 2014-02-12 10:04:35 ESH13 | 2014-02-12 10:04:35 ESM13 | 2014-02-12 10:04:35 ESU13 | 2014-02-12 10:04:35 ESZ13 | 2014-02-12 10:04:35 ESH14 | 2014-02-12 10:04:35 Volume based rollover from ESH11 to ESM11 occurs at 2011-03-11 | 2014-02-12 10:04:35 Volume based rollover from ESM11 to ESU11 occurs at 2011-06-10 | 2014-02-12 10:04:35 Volume based rollover from ESU11 to ESZ11 occurs at 2011-09-09 | 2014-02-12 10:04:35 Volume based rollover from ESZ11 to ESH12 occurs at 2011-12-09 | 2014-02-12 10:04:35 Volume based rollover from ESH12 to ESM12 occurs at 2012-03-09 | 2014-02-12 10:04:35 Volume based rollover from ESM12 to ESU12 occurs at 2012-06-08 | 2014-02-12 10:04:35 Volume based rollover from ESU12 to ESZ12 occurs at 2012-09-14 | 2014-02-12 10:04:35 Volume based rollover from ESZ12 to ESH13 occurs at 2012-12-14 | 2014-02-12 10:04:35 Volume based rollover from ESH13 to ESM13 occurs at 2013-03-08 | 2014-02-12 10:04:35 Volume based rollover from ESM13 to ESU13 occurs at 2013-06-14 | 2014-02-12 10:04:35 Volume based rollover from ESU13 to ESZ13 occurs at 2013-09-13 | 2014-02-12 10:04:35 Volume based rollover from ESZ13 to ESH14 occurs at 2013-12-13 | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: Performing continuous futures contract back adjustment calculations. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESH11 Open price on 2011-03-11 is 1293.75. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESM11 Open price on 2011-03-11 is 1289. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESH11 price difference to ESM11 is -4.75. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESM11 Open price on 2011-06-10 is 1287.75. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESU11 Open price on 2011-06-10 is 1282.25. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESM11 price difference to ESU11 is -5.5. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESU11 Open price on 2011-09-09 is 1185.75. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESZ11 Open price on 2011-09-09 is 1180. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESU11 price difference to ESZ11 is -5.75. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESZ11 Open price on 2011-12-09 is 1235.5. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESH12 Open price on 2011-12-09 is 1229.75. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESZ11 price difference to ESH12 is -5.75. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESH12 Open price on 2012-03-09 is 1366.25. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESM12 Open price on 2012-03-09 is 1360.25. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESH12 price difference to ESM12 is -6. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESM12 Open price on 2012-06-08 is 1316.25. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESU12 Open price on 2012-06-08 is 1309.5. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESM12 price difference to ESU12 is -6.75. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESU12 Open price on 2012-09-14 is 1456.5. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESZ12 Open price on 2012-09-14 is 1450. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESU12 price difference to ESZ12 is -6.5. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESZ12 Open price on 2012-12-14 is 1416.75. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESH13 Open price on 2012-12-14 is 1410.5. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESZ12 price difference to ESH13 is -6.25. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESH13 Open price on 2013-03-08 is 1542.75. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESM13 Open price on 2013-03-08 is 1538. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESH13 price difference to ESM13 is -4.75. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESM13 Open price on 2013-06-14 is 1637.75. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESU13 Open price on 2013-06-14 is 1631.5. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESM13 price difference to ESU13 is -6.25. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESU13 Open price on 2013-09-13 is 1684.75. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESZ13 Open price on 2013-09-13 is 1678.25. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESU13 price difference to ESZ13 is -6.5. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESZ13 Open price on 2013-12-13 is 1773.5. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESH14 Open price on 2013-12-13 is 1767. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: ESZ13 price difference to ESH14 is -6.5. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESH11 is -71.25. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESM11 is -66.5. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESU11 is -61. | 2014-02-12 10:04:35 HD Request # 3 - Requesting up to 1095 days of Intraday data. Record interval: 1 | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESZ11 is -55.25. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESH12 is -49.5. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESM12 is -43.5. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESU12 is -36.75. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESZ12 is -30.25. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESH13 is -24. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESM13 is -19.25. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESU13 is -13. | 2014-02-12 10:04:35 ESH4 [CBV] Daily #1: Back adjust amount for symbol ESZ13 is -6.5. | 2014-02-12 10:04:35 The network socket for historical data has been closed. | 2014-02-12 10:04:35 HD Request # 3 - Historical data for ESH4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-02-12 10:04:35 HD Request # 3 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH4 | 2014-02-12 10:04:35 HD Request # 3 - Intraday download COMPLETE for ESH4 | 2014-02-12 10:04:35 HD Request # 4 - Downloading Intraday chart data for ZWH4 to the file ZWH4.scid. Service: oec | 2014-02-12 10:04:35 HD Request # 4 - Download start Date-Time: 2014-02-12 10:02:00.0 | 2014-02-12 10:04:35 HD Request # 4 - Using server: ds5.sierracharts.com port 80 | 2014-02-12 10:04:35 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-02-12 10:04:35 The network socket is connected. | 2014-02-12 10:04:35 HD Request # 4 - Sending historical data logon request message. | 2014-02-12 10:04:35 The network socket for historical data has been closed. | 2014-02-12 10:04:35 HD Request # 4 - Error downloading historical Intraday data for ZWH4. Historical data logon error: Serving data is disabled. | 2014-02-12 10:04:35 HD Request # 4 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZWH4 | 2014-02-12 10:04:35 HD Request # 5 - Downloading Intraday chart data for ZWH4 to the file ZWH4.scid. Service: oec | 2014-02-12 10:04:35 HD Request # 5 - Download start Date-Time: 2014-02-12 10:02:00.0 | 2014-02-12 10:04:35 HD Request # 5 - Using server: ds3.sierracharts.com port 80 | 2014-02-12 10:04:35 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-02-12 10:04:35 The network socket is connected. | 2014-02-12 10:04:35 HD Request # 5 - Sending historical data logon request message. | 2014-02-12 10:04:35 The network socket for historical data has been closed. | 2014-02-12 10:04:35 HD Request # 5 - Error downloading historical Intraday data for ZWH4. Historical data logon error: Serving data is disabled. | 2014-02-12 10:04:35 HD Request # 5 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZWH4 | 2014-02-12 10:04:35 HD Request # 6 - Downloading Intraday chart data for ZWH4 to the file ZWH4.scid. Service: oec | 2014-02-12 10:04:35 HD Request # 6 - Download start Date-Time: 2014-02-12 10:02:00.0 | 2014-02-12 10:04:35 HD Request # 6 - Using server: ds4.sierracharts.com port 80 | 2014-02-12 10:04:35 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-02-12 10:04:35 The network socket is connected. | 2014-02-12 10:04:35 HD Request # 6 - Sending historical data logon request message. | 2014-02-12 10:04:35 HD Request # 6 - Requesting all Intraday data available. Record interval: 1 | 2014-02-12 10:04:36 The network socket for historical data has been closed. | 2014-02-12 10:04:36 HD Request # 6 - Historical data for ZWH4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-02-12 10:04:36 HD Request # 6 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZWH4 | 2014-02-12 10:04:36 HD Request # 6 - Intraday download COMPLETE for ZWH4 | 2014-02-12 10:04:36 Open E Cry FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-02-12 10:04:36 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-02-12 10:04:36 The network socket is connected. | 2014-02-12 10:04:36 The socket starting SSL connection. | 2014-02-12 10:04:36 SSL socket is now connected. | 2014-02-12 10:04:36 OEC FIX Trading session: Sending the Logon message. | 2014-02-12 10:04:36 Open E Cry FIX/FAST: Connected to trading server. | 2014-02-12 10:04:37 Open E Cry FIX/FAST: Connecting to FAST market data server: prod.openecry.com:9301. | 2014-02-12 10:04:37 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-02-12 10:04:37 The network socket is connected. | 2014-02-12 10:04:37 OEC FAST Market Data session: Sending the Hello message. | 2014-02-12 10:04:37 OEC FAST Market Data session: Sending the Logon message. | 2014-02-12 10:04:37 Open E Cry FIX/FAST: Connected to the market data server. | 2014-02-12 10:04:37 Open E Cry FIX/FAST: Connected. | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: ZWH4 | 2014-02-12 10:04:37 HD Request # 7 - Downloading Intraday chart data for ZWH4 to the file ZWH4.scid. Service: oec | 2014-02-12 10:04:37 HD Request # 7 - Download start Date-Time: 2014-02-12 10:02:00.0 | 2014-02-12 10:04:37 HD Request # 7 - Using server: ds5.sierracharts.com port 80 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: ESH4 | 2014-02-12 10:04:37 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: YMH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: NQH4 | 2014-02-12 10:04:37 No SC real-time data feed mapping found for symbol: RLM-MH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: RLM-MH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: NKDH4 | 2014-02-12 10:04:37 No SC real-time data feed mapping found for symbol: DX-MH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: DX-MH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: 6EH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: 6JH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: 6BH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: 6AH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: 6CH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: 6SH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: ZNH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: ZFH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: GHGH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: GSIH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: GGCJ4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: GCLH4 | 2014-02-12 10:04:37 No SC real-time data feed mapping found for symbol: NSEA-MH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: NSEA-MH4 | 2014-02-12 10:04:37 No SC real-time data feed mapping found for symbol: ARA-MH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: ARA-MH4 | 2014-02-12 10:04:37 No SC real-time data feed mapping found for symbol: WTI-MH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: WTI-MH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: GNGH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: GRBH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: ZCH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: ZLH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: ZSH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: ZMH4 | 2014-02-12 10:04:37 No SC real-time data feed mapping found for symbol: CC-MH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: CC-MH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: KC-MH4 | 2014-02-12 10:04:37 No SC real-time data feed mapping found for symbol: CT-MH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: CT-MH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: SB-MH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: GFH4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: HEJ4 | 2014-02-12 10:04:37 Open E Cry FIX/FAST - Starting real-time market data updates for: LEJ4 | 2014-02-12 10:04:37 The network socket is connected. | 2014-02-12 10:04:37 HD Request # 7 - Sending historical data logon request message. | 2014-02-12 10:04:37 Symbol Error - GHGH4 is unknown, unavailable, or improperly formatted. FIX reject reason: Your subscription limit of 15 has been reached | 2014-02-12 10:04:37 The network socket for historical data has been closed. | 2014-02-12 10:04:37 HD Request # 7 - Error downloading historical Intraday data for ZWH4. Historical data logon error: Serving data is disabled. | 2014-02-12 10:04:37 HD Request # 7 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZWH4 | 2014-02-12 10:04:37 HD Request # 7 - Receiving Intraday data for ZWH4 starting at 2014-02-12 10:04:14 | 2014-02-12 10:04:37 HD Request # 7 - Timestamp of first Intraday data file record written: 2014-02-12 10:04:14 | 2014-02-12 10:04:37 Added 1 Time and Sales records to Intraday data file for ZWH4 after download. | 2014-02-12 10:04:37 HD Request # 8 - Downloading Intraday chart data for ZWH4 to the file ZWH4.scid. Service: oec | 2014-02-12 10:04:37 HD Request # 8 - Download start Date-Time: 2014-02-12 10:02:00.0 | 2014-02-12 10:04:37 HD Request # 8 - Using server: ds3.sierracharts.com port 80 | 2014-02-12 10:04:37 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-02-12 10:04:37 The network socket is connected. | 2014-02-12 10:04:37 HD Request # 8 - Sending historical data logon request message. | 2014-02-12 10:04:37 The network socket for historical data has been closed. | 2014-02-12 10:04:37 HD Request # 8 - Error downloading historical Intraday data for ZWH4. Historical data logon error: Serving data is disabled. | 2014-02-12 10:04:37 HD Request # 8 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZWH4 | 2014-02-12 10:04:37 HD Request # 8 - Receiving Intraday data for ZWH4 starting at 2014-02-12 10:04:14 | 2014-02-12 10:04:37 HD Request # 8 - Timestamp of first Intraday data file record written: 2014-02-12 10:04:14 | 2014-02-12 10:04:37 Added 1 Time and Sales records to Intraday data file for ZWH4 after download. | 2014-02-12 10:04:37 HD Request # 9 - Downloading Intraday chart data for ZWH4 to the file ZWH4.scid. Service: oec | 2014-02-12 10:04:37 HD Request # 9 - Download start Date-Time: 2014-02-12 10:02:00.0 | 2014-02-12 10:04:37 HD Request # 9 - Using server: ds4.sierracharts.com port 80 | 2014-02-12 10:04:37 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-02-12 10:04:37 The network socket is connected. | 2014-02-12 10:04:38 HD Request # 9 - Sending historical data logon request message. | 2014-02-12 10:04:38 HD Request # 9 - Requesting all Intraday data available. Record interval: 1 | 2014-02-12 10:04:38 HD Request # 9 - Decompressing data. | 2014-02-12 10:04:38 HD Request # 9 - Receiving Intraday data for ZWH4 starting at 2014-02-12 10:02:00 | 2014-02-12 10:04:38 HD Request # 9 - Timestamp of first Intraday data file record written: 2014-02-12 10:02:00 | 2014-02-12 10:04:38 The network socket for historical data has been closed. | 2014-02-12 10:04:38 HD Request # 9 - Received 12 records from 2014-02-12 10:02:00 to 2014-02-12 10:04:14 (2.2 minutes) and wrote 12 records for ZWH4 | 2014-02-12 10:04:38 HD Request # 9 - Intraday download COMPLETE for ZWH4 | 2014-02-12 10:04:38 Real-time Intraday chart data file updates started for ZWH4 | 2014-02-12 10:04:38 HD Request # 10 - Downloading Intraday chart data for ESH4 to the file ESH4.scid. Service: oec | 2014-02-12 10:04:38 HD Request # 10 - Download start Date-Time: 2014-02-12 10:03:12.0 | 2014-02-12 10:04:38 HD Request # 10 - Using server: ds5.sierracharts.com port 80 | 2014-02-12 10:04:38 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-02-12 10:04:38 The network socket is connected. | 2014-02-12 10:04:38 HD Request # 10 - Sending historical data logon request message. | 2014-02-12 10:04:38 The network socket for historical data has been closed. | 2014-02-12 10:04:38 HD Request # 10 - Error downloading historical Intraday data for ESH4. Historical data logon error: Serving data is disabled. | 2014-02-12 10:04:38 HD Request # 10 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH4 | 2014-02-12 10:04:38 HD Request # 10 - Receiving Intraday data for ESH4 starting at 2014-02-12 10:04:29 | 2014-02-12 10:04:38 HD Request # 10 - Timestamp of first Intraday data file record written: 2014-02-12 10:04:29 | 2014-02-12 10:04:38 Added 1 Time and Sales records to Intraday data file for ESH4 after download. | 2014-02-12 10:04:38 HD Request # 11 - Downloading Intraday chart data for ESH4 to the file ESH4.scid. Service: oec | 2014-02-12 10:04:38 HD Request # 11 - Download start Date-Time: 2014-02-12 10:03:12.0 | 2014-02-12 10:04:38 HD Request # 11 - Using server: ds3.sierracharts.com port 80 | 2014-02-12 10:04:38 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-02-12 10:04:38 The network socket is connected. | 2014-02-12 10:04:38 HD Request # 11 - Sending historical data logon request message. | 2014-02-12 10:04:38 The network socket for historical data has been closed. | 2014-02-12 10:04:38 HD Request # 11 - Error downloading historical Intraday data for ESH4. Historical data logon error: Serving data is disabled. | 2014-02-12 10:04:38 HD Request # 11 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH4 | 2014-02-12 10:04:38 HD Request # 11 - Receiving Intraday data for ESH4 starting at 2014-02-12 10:04:29 | 2014-02-12 10:04:38 HD Request # 11 - Timestamp of first Intraday data file record written: 2014-02-12 10:04:29 | 2014-02-12 10:04:38 Added 1 Time and Sales records to Intraday data file for ESH4 after download. | 2014-02-12 10:04:38 HD Request # 12 - Downloading Intraday chart data for ESH4 to the file ESH4.scid. Service: oec | 2014-02-12 10:04:38 HD Request # 12 - Download start Date-Time: 2014-02-12 10:03:12.0 | 2014-02-12 10:04:38 HD Request # 12 - Using server: ds4.sierracharts.com port 80 | 2014-02-12 10:04:38 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-02-12 10:04:38 The network socket is connected. | 2014-02-12 10:04:38 HD Request # 12 - Sending historical data logon request message. | 2014-02-12 10:04:38 HD Request # 12 - Requesting all Intraday data available. Record interval: 1 | 2014-02-12 10:04:38 HD Request # 12 - Decompressing data. | 2014-02-12 10:04:39 HD Request # 12 - Receiving Intraday data for ESH4 starting at 2014-02-12 10:03:12 | 2014-02-12 10:04:39 HD Request # 12 - Timestamp of first Intraday data file record written: 2014-02-12 10:03:12 | 2014-02-12 10:04:39 The network socket for historical data has been closed. | 2014-02-12 10:04:39 HD Request # 12 - Received 25 records from 2014-02-12 10:03:12 to 2014-02-12 10:04:29 (77.0 seconds) and wrote 25 records for ESH4 | 2014-02-12 10:04:39 HD Request # 12 - Intraday download COMPLETE for ESH4 | 2014-02-12 10:04:39 Real-time Intraday chart data file updates started for ESH4 | 2014-02-12 10:04:39 |
[2014-02-12 18:08:37] |
Not exactly sure but this Open E Cry FIX/FAST version doesn't seem to be as stable as a previous version i had. Does this matter at all? |
[2014-02-12 18:31:29] |
OEC has set the limit to 15: Symbol Error - GHGH4 is unknown, unavailable, or improperly formatted. FIX reject reason: Your subscription limit of 15 has been reached | 2014-02-12 10:04:37 And you are tracking 35 symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-12 18:41:20
[2014-02-12 18:33:27] |
the code in last post shows some prices being correct, while others i have to disconnect/reconnect
[2014-02-12 18:39:05] |
We do not need to see another Message Log. The last one posted has been deleted. Please see our response given in post #18. At this point, really our recommendation is as follows: Use another trading service other than OEC. Clearly it is not meeting your symbol requirements. All of the supported services can be found here: http://www.sierrachart.com/index.php?l=doc/data.php Or use the Sierra Chart Real-time and Historical Data Feed: http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php At this point, we cannot provide further help on this subject. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-12 18:41:34
[2014-02-12 19:05:23] |
ill try that service, can you give me an example of how it would benefit me ( 35-80 symbols is ok. ? )
Date Time Of Last Edit: 2014-02-12 19:08:43
[2014-02-13 08:52:56] |
The Sierra Chart Real-time and Historical Data Feed can easily handle 80 symbols. It will benefit you because you will not have any market data problems. Everything will work perfect. Are you just looking at the CME markets?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-13 08:53:20
