Date/Time: Fri, 18 Sep 2026 04:52:48 +0000
Order lines on top
View Count: 784
[2020-10-07 14:28:12]
EuropeanTrader - Posts: 290
I cannot seem to find a setting that would display my chart orders line above anything I draw or write.
Please see the attached screenshot that shows my order line hidden behind those objects.
How can I do that, please?
Thank you!
Greg
imageSH_ 7873 Oct. 07 16.28.jpg / V - Attached On 2020-10-07 14:28:00 UTC - Size: 7.52 KB - 264 views
[2020-10-07 15:02:42]
John - SC Support - Posts: 47930
You need to set the drawings to be drawn behind the other items. Refer to the following setting and the one after it:
Chart Settings: Draw Non-Highlight Chart Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Chart Drawings menu)
