Date/Time: Wed, 12 Feb 2025 10:39:06 +0000
Quote Spreadsheet not updating following upgrade from 2163 to 2177
View Count: 651
[2020-10-07 09:35:52] |
trader0222 - Posts: 30 |
Hi, My existing quote spreadsheet is not self updating after I made the upgrade? What can be wrong? Things I've tried and tested 1. Toggled "Quote Spreadsheet" on and off under the Spreadsheet menu 2. Restarting Sierra Chart 3. Attaching/Detaching the Quote Spreadsheet window. 4. Create new quote spreadsheet and added a few quotes - New quotes are working and updating instantly Thank you in advance. |
[2020-10-07 18:56:34] |
We will check on this. We did some work on this. Can you attach the spreadsheet which has this issue. Instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-07 22:45:59] |
IconBob - Posts: 61 |
Same problem. works on version 2175 but quote spreadsheet is frozen.
[2020-10-08 06:33:01] |
Attaching file
[2020-10-08 18:43:50] |
We will get this resolved in the next release which we will have out this evening.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-08 18:44:14
[2020-10-25 23:30:38] |
This has been resolved. Update to the latest release: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
