Date/Time: Sun, 08 Sep 2024 00:25:30 +0000
Documentation?
View Count: 1151
[2014-02-10 14:27:56] |
pismo10 - Posts: 159 |
Is there any documentation posted to explain High Pullback and Low Pullback options in the study Numbers Bars Calculated values? Thanks SL |
[2014-02-10 17:20:02] |
We need to work on documentation for this.
[2014-02-10 17:20:58] |
They read zero all the time? Still in development? or?
[2014-02-11 08:19:31] |
Thinking about this you will need to activate Chart >> Chart Settings >> Advanced Settings >> Historical Pullback Data, to make those work.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-14 01:01:40
[2014-02-14 01:00:53] |
Documentation for these Subgraphs have been added here: https://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#SubgraphDescriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
