Date/Time: Wed, 12 Feb 2025 07:29:48 +0000
Problem with TPO chart
View Count: 682
[2020-10-07 06:37:54] |
User623005 - Posts: 12 |
Hi, I am having seemingly strange issue with my TPO charts. With eurex instruments like STOXX and Bund there is no split between morning and evening sessions despite in settings I specified that. After double rechecking settings I copied tpo chart from US markets (SP in particular) on which morning/evening profiles are splitting perfectly, changed the session times and instrument code and the split disappeared. Settings screnshots attached. Please advise
Private File Private File Private File |
[2020-10-08 09:58:25] |
Provide that chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-08 12:47:22] |
File attached
[2020-10-08 21:46:48] |
We are looking this over. We will see what the issue is.
[2020-10-09 19:35:28] |
This has been resolved . Update to the latest prerelease (2178) by following these instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
