Date/Time: Wed, 12 Feb 2025 04:33:41 +0000
"Confirm Order Modifications" Gets Checked Automatically
View Count: 613
[2020-10-06 19:53:05] |
ondafringe - Posts: 298 |
I have never used any type of confirmation for any type of order, but for the last two versions of SC, whenever I place an order using the DOM, "Confirm Order Modifications" gets checked automatically. I uncheck it, but after placing the next order, it gets checked again automatically. So far, I haven't been able to locate a default setting that might be causing that.
[2020-10-06 20:51:24] |
Ackin - Posts: 1865 |
Try: Trade Window Main/C >> Menu >> Order Confirmations (chart specific) Basic Trading and the Trade Window: Main/C >> Menu >> Order Confirmations (chart specific) Main/C >> Menu >> Save Configuration Basic Trading and the Trade Window: Main/C >> Menu >> Save Configuration + Disable Order Confirmations - Global (Global Settings >> Chart Trade Settings) Global Trade Settings Windows: Disable Order Confirmations - Global (Global Settings >> Chart Trade Settings >> General >> Confirmations) Date Time Of Last Edit: 2020-10-06 21:08:07
[2020-10-06 21:15:35] |
Yes here is the relevant documentation: Basic Trading and the Trade Window: Main/C >> Menu >> Order Confirmations (chart specific) You may be changing the Trade Window Configuration which is causing the order confirmation to become reenabled if it was enabled when the configuration was saved. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-06 22:23:47] |
Yeah, the global setting was unchecked. So rechecked that. Then made certain no confirmations where checked and re-saved the Trade Window configuration. Hopefully, that does it. Okay, thanks to both of you! :) |
