Date/Time: Wed, 12 Feb 2025 04:10:36 +0000
Alert message blank
View Count: 413
[2020-10-06 15:54:45] |
N!co - Posts: 140 |
hi, you have any idea why my Alert popup window iss blank, where before if showed what alert was triggered ? thx |
[2020-10-07 05:20:56] |
You need to update Sierra Chart to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
