Date/Time: Wed, 16 Sep 2026 22:10:06 +0000
Error coneccion
View Count: 629
| [2020-10-06 15:15:57] |
| User130874 - Posts: 1 |
Buenos días El día de hoy he intentado ingresar a mi cuenta iniciar sesion en sierra chart pero me dice que esta desactivado, me podrian ayudar con el tema gracias. |
| [2020-10-06 16:25:38] |
| John - SC Support - Posts: 47917 |
From Google Translate: Good Morning
Today I tried to enter my account to log into sierra chart but it tells me that it is deactivated, could you help me with the issue, thanks The account that from which you posted to the Support Board is not expired or deactivated. Therefore, as long as you are logging in with that account, you should not have a problem. The only thing you can try to do is to use the Forced Login option to ensure that your local account information is up to date with our servers. Refer to the following information for how to perform a Forced Login: Sierra Chart - Software Login Instructions: Forced Login[/quote] For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-06 16:25:47
