Date/Time: Wed, 12 Feb 2025 04:20:10 +0000
Web based Order Panel
View Count: 605
[2020-10-06 15:14:49] |
User531863 - Posts: 6 |
Hi there, why do i get now data for the CME (ES) in the WEB Panel? In my live account i get no data at all! In the sim account it is delayed. |
[2020-10-07 18:47:27] |
There is no market data support in the web trading panel. Can you provide us a screenshot of what you are seeing. If you are not receiving real-time data within Sierra Chart, follow the instructions below: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-07 18:47:32
[2020-10-07 19:55:25] |
I have no problems within Sierra! I thougt the web panel is a kind of backup if the PC fails for example. So if i understand you right there is no price data in the web panel available? Thanks |
Private File |
[2020-10-08 09:54:02] |
Yes that is correct.
