Date/Time: Wed, 12 Feb 2025 04:35:56 +0000
Plotting 2 Volume Profiles
View Count: 1076
[2020-10-06 14:39:58] |
MikeVon - Posts: 20 |
Hello, I would like to plot 2 Volume Profiles which overlap on the right side of the chart. 1. A daily right - alligned session profile 2. A multiday volume profile outline I would like both to be "stuck to the right hand scale and would like to be able to move the underlying price chart without moving the profiles. I can make this happen by selecting "Always display last Profile within view" on both profiles but then the profiles are stacked and do not overlap. Is there a way to set this that both profiles overlap and are stuck to the right scale? Thank You for the help. http://www.sierrachart.com/image.php?Image=1601995154734.png Date Time Of Last Edit: 2020-10-06 15:05:17
[2020-10-06 15:35:09] |
User907968 - Posts: 826 |
Disable 'Allow Side-by-Side Profiles on Right Side' Volume By Price Study: Allow Side-By-Side Profiles on Right Side |
