Date/Time: Thu, 17 Sep 2026 01:55:32 +0000
CME data changes to incorrect values
View Count: 810
| [2020-10-06 13:42:01] |
| profitmotive - Posts: 5 |
My TPO charts are changing values and are not accurate. The low of 10/05 is 3360.50 and that was what the chart showed yesterday while I was trading. This morning it shows 3364.50. I deleted data and downloaded and I also upgraded to the current version of Sierra. Neither of these made any difference. Can you please help me determine what is going on? I have been using these TPO charts for months without issue. Screenshot link http://www.sierrachart.com/image.php?Image=1601991614414.png |
| [2020-10-06 16:07:27] |
| John - SC Support - Posts: 47917 |
Make sure your Session Times are set properly and do not overlap (for example, enter 15:59:59 rather than 16:00:00 for the End Time). If this is not the issue, then attach a Chartbook with just the one chart in it to this thread so we can take a look. Refer to the instructions here: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-10-06 16:17:22] |
Thank you. That fixed it. I changed my evening session end time to 8:29:59 from 8:30:00. Thanks again. Will |
