Date/Time: Mon, 25 Nov 2024 12:27:16 +0000
NQ Historical Chart load wrong symbol
View Count: 1102
[2014-02-10 10:14:16]
timokrates - Posts: 28
I'm not able to load a historical chart for the NQ anymore.
Via "Find Symbol" or even manually it always loads BZ-201403-NYMEX.
I'm using IB and version 1090.
Also I have problems to display longer periods of intraday data on the 60M or so.
Do I have to merge contracts?
[2014-02-10 16:59:42]
That does not make sense.
Must be something significantly wrong with the symbol settings.
Perform a Full Reset of the Symbol Settings as explained here:
https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings
[2014-02-10 17:00:57]
What specific problem?
You do not need to merge or join futures contract data files. There is a new Continuous Futures Contract feature you can use:
https://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html
