Date/Time: Wed, 12 Feb 2025 04:32:02 +0000
scaling overlay (bar) graphs
View Count: 523
[2020-10-06 06:11:07] |
User425645 - Posts: 113 |
Hello, As you can see in the image attached below - I am unable to scale the overlaid graph, I'm only able to change the scales on the base graph. How do I change the overlayed graphs scale as well?? Thanks |
[2020-10-06 06:47:42] |
Refer to this page: Chart Scale and Scale Adjusting And also refer to this particular subsection: Chart Scale and Scale Adjusting: Left Side Scale - Interactive Scale Range/Move (Left Side Scale - Interactive Scale Range/Move) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-06 06:48:15
