Date/Time: Wed, 12 Feb 2025 04:22:48 +0000
Data Feed Service
View Count: 441
[2020-10-05 21:09:43] |
Trader77 - Posts: 2 |
Hi, Since you don't support Rithmic connections, I want to know what Data Feed service I can subscribed in Sierra Chart to get real time data feed for /ES, and /NQ? |
[2020-10-05 22:05:03] |
John - SC Support - Posts: 37891 |
You can use the Denali Exchange Data Feed that is provided by us. Refer to the information here for this data feed: Denali Exchange Data Feed But the bigger question is what Trading Service will you be using, as you need to be able to connect to a funded trading account in order to qualify for the lower priced Non-Professional exchange pricing from the CME Group. Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Also, refer to the information here for what services we support: Supported Data and Trading Services: Supported Services And finally, if you just want a way to deal with the CME group stuff, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-05 22:25:59] |
Is Dorman Trading account is supported as a funded account? Since it's Rithmic based, I don't know how to connect it.
[2020-10-06 07:26:32] |
Not if it is using Rithmic. In this case, follow this solution: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
