Date/Time: Wed, 12 Feb 2025 04:11:09 +0000
number of denali feed applications
View Count: 468
[2020-10-05 17:58:52]
Don H - Posts: 31
In the description of Denali it says you can run/use feed into 2 applications on the same computer. If you have a laptop and a desktop can you have one computer closed and run the two feeds on the other computer, then when completed shut that one down and run the second computer with the two feed applications. Or can you only run the feed on one sole computer that doesn't change.
[2020-10-05 20:03:41]
John - SC Support - Posts: 37891
Yes, you can do what you have suggested. But you have to have ensure that Sierra Chart is not connected on the computer that is not in use whenever you make a switch.
