Date/Time: Fri, 02 Oct 2026 21:14:01 +0000
Autotrade System replay backtest stopped working
View Count: 1157
[2020-10-05 17:23:07]
PanCSI - Posts: 9
I have created a custom study which I am trying to backtest using the "Autotrade System replay backtest" feature.
Until yesterday I was able to run the backtest for the dates that I wanted to, but today I can't.
I have just purchased a license for SierraChart today (level 5 package), and I could run the backtest before but not after purchasing.
I am connected to "SC Data - All Services" trade service.
I tried recompiling the study, running both in 32 bit and 64 bit mode, but to no avail.
I can't quite figure out what has changed, so I would like some help on how to debug or backtrack this to the root cause of the issue.
Thank you.
[2020-10-06 07:22:56]
The first question is, is do you see the chart advance forward in time after selecting Trade >> Autotrade System Replay Back Test?
If you have any performance issues with back testing, then refer to:
Auto Trade System Back Testing: Improving Back Test Performance
[2020-10-08 12:01:36]
PanCSI - Posts: 9
Yes,
I do see the chart moving.
This might just be some setting having changed inadvertently.
I see a message that I haven't noticed: Setting study DLL module function objects to indicate DLL is not loaded: D:\SierraChart\Data\LevStd.dll
[2020-10-08 19:49:43]
If that DLL is what contains the automated trading system, then that sounds like where the problem is. It sounds like there is a problem loading the DLL.
Provide the exact error message here by copying and pasting that line from the Message Log.
Date Time Of Last Edit: 2020-10-08 19:50:07
