Date/Time: Sun, 23 Feb 2025 14:41:34 +0000
Option > Color Connecting Lines Based on Profit/Loss > does not work
View Count: 1641
[2014-02-09 23:20:33] |
User51760 - Posts: 108 |
Dear Sierra Chart Team, the option "Global Settings >> Chart Trade Settings >> Color Connecting Lines Based On Profit/Loss" seems not to work in Sierra Chart 1090 and I cannot find it documented in Sierra Charts Documentation http://www.sierrachart.com/index.php?l=doc/doc_GlobalTradeSettings.html#ChartTradeSettings Please point me into the right direction with a link explaining how the function should work or let me know here... Thank you for your consideration, Best, Chris |
[2014-02-11 08:20:31] |
We have tested this and we did not see a problem. Check the Color Settings in Global Settings >> Graphics Settings. They are: Chart Trading Order Fill Entry/Exit Connecting Lines Primary Chart Trading Order Fill Entry/Exit Connecting Lines Secondary We also will be updating the documentation later today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-11 08:20:53
[2014-02-11 14:02:16] |
Dear Sierra Chart Team, thank you for your fast reply. You are right, there is no problem. I was not aware of the Global Settings >> Graphic Settings >> Chart Trading Order Fill Entry/Exit Connecting Lines Primary + Chart Trading Order Fill Entry/Exit Connecting Lines Secondary. Now it is working perfectly. Thank you for your support, Best, Chris |
[2014-02-12 08:41:17] |
The documentation has now been updated to explain the color settings for order fill connecting lines. Also some of the related terminology has changed in the program and the documentation has been updated to use that new terminology. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-12 10:51:22] |
Thank you for your fast support! Best, Chris |
[2021-02-16 18:35:54] |
User30743 - Posts: 365 |
how to connect entry-exit with a line? i had it previously but now i cant make it work - have it like this https://prnt.sc/zrbn9e and also on graph setting i have it set https://prnt.sc/zrbqxm but still i cant see the lines, only the flags. what am I missing? |
[2021-02-16 18:43:43] |
John - SC Support - Posts: 38116 |
Refer to the following setting: Global Trade Settings Windows: Display Entry/Exit Connecting Lines (Global Settings >> Chart Trade Settings >> Order Fills >> Order Fills) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
