Date/Time: Sat, 19 Sep 2026 16:58:25 +0000
el grafico no se mueve
View Count: 940
[2020-10-05 15:14:41]
gabriel Mendez - Posts: 5
hola ,estoy intentando ver el grafico mini sp 500 MES, pero no se mueve en absoluto ,quisiera ayuda para resolver el problema
[2020-10-05 15:39:47]
John - SC Support - Posts: 47939
From Google Translate:
hi, i'm trying to see the mini sp 500 MONTH chart, but it doesn't move at all, i would like help to solve the problem
Refer to the information here:
Not Receiving Delayed Exchange Data Feed?
[2020-10-05 16:32:34]
TENGO QUE PAGAR DINERO POR ESO?
[2020-10-05 16:55:11]
Do I have to pay money for that?
No, you do not have to pay any extra for the Delayed Exchange Data Feed. Refer to the information here:
[2020-10-05 17:02:11]
Hice los pasos y el grafico sigue sin movimiento
[2020-10-05 17:30:00]
I did the steps and the graph is still without movement
Your agreement has not yet been processed. You can review the status of your agreement at the bottom of this page:
https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements
Once the agreement has been processed, if you still do not have the streaming delayed data, then follow these instructions for a "forced login" which ensures that your information from our servers gets updated:
Sierra Chart - Software Login Instructions: Forced Login
[2020-10-05 19:03:15]
listo ahora si se mueve el grafico ,esta aceptando datos,muchas gracias por ayudarme,saludos y buena suerte. exelente
[2020-10-05 20:12:45]
Your agreement has been approved, so just go through the process for Forced Login which is explained here:
