Date/Time: Wed, 12 Feb 2025 04:13:38 +0000
Point & Figure Charts - auto centering
View Count: 568
[2020-10-04 23:10:54] |
User794190 - Posts: 26 |
I use a Point-and-Figure chart as a secondary tool trading. If price moves too far up or too far down, I must manually adjust the screen so that the current price is visible. Can this adjustment be done automatically?
[2020-10-04 23:36:03] |
Yes if an Automatic Scale Range is used: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
