Date/Time: Wed, 12 Feb 2025 04:03:18 +0000
delayed data feed
View Count: 588
[2020-10-04 19:55:16] |
User428203 - Posts: 1 |
I paid 36$ as usual for service package and denali data feed. Usage Time ending date 2020 10 31. Data are „delayed” (information on chart). I dont know where is a problem greetings |
[2020-10-05 06:03:46] |
You are not currently using the Denali Exchange Data Feed. You need to follow the instructions here for that: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* Or you can use the Delayed Exchange Data Feed: Delayed Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
