Date/Time: Wed, 12 Feb 2025 04:22:47 +0000
A question on stocks scanning
View Count: 734
[2020-10-04 15:46:45] |
User999647 - Posts: 38 |
Hi, I imported 201 US stocks tickers in to the Associated Watch List. Then in Alert Condition I entered the following: =AV > BV . So the aim was to scan my list for those ask volume higher than the bid volume. By the way, the charts are intraday daily charts. After running the scan, there are a few things very confusing: 1. when I am checking the results, I found that NIO and PENN are in the Alert Manager. However, bid volume is actually higher than ask volume for both of them. So the scanning result includes the stocks which are totally opposite to the scan criteria. 2. I have run both = AV > BV and = AV < BV for my 201 stock tickers. It turns out I got 39 results for AV > BV and 40 results for AV < BV making a total of 79. So does it mean out of my 201 tickers, 122 tickers have got AV and BV exactly the same? Am I missing something here in screening? I just does not look right. |
[2020-10-05 07:00:14] |
It is really impossible for us to know what the issue is unless we were to examine this issue directly which we cannot do without a remote assistance session. Make sure this option is enabled: Global Settings >> General Settings >> General 2 >> Subscribe Real-time (RT) Data and Download Historical Data During Scan And definitely update Sierra Chart to the current version: Software Download: Fast Update (This is mandatory) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-05 07:00:25
