Date/Time: Wed, 12 Feb 2025 04:31:43 +0000
export datat for zipline
View Count: 513
[2020-10-04 03:28:32] |
qiw4u23oi4u234 - Posts: 34 |
Hi, is there any way to export the data for stocks/futures from sierrachart in order to ingest them into a zipline bundle to perform backtests with python? |
[2020-10-05 06:31:52] |
Refer to: Text/CSV Data Format Exporting and Importing Intraday Data Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
