Date/Time: Wed, 12 Feb 2025 04:30:00 +0000
[User Discussion] - Data in chart header
View Count: 539
[2020-10-03 14:25:33] |
User203781 - Posts: 55 |
Is it possible to display data (OHLC, indicator values, etc.) for the bar at the cursor position instead of the last bar on the screen? If so, how? If not, please consider this an urgent request for a feature upgrade. Thanks. |
[2020-10-04 03:33:11] |
Not in the chart header if the chart is still scrolled to the end, but in other windows. Refer to: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-04 03:33:20
