Date/Time: Mon, 25 Nov 2024 12:30:45 +0000
#VALUE! error on buy/sell entries
View Count: 1202
[2014-02-09 14:59:33] |
Litz - Posts: 131 |
Trying to add a check for position condition prior to buy/sell entry formulas. ie =AND($J$8<=0),CROSSFROMBELOW(AH3:AH5,AI3:AI5) but get a #VALUE! error result on entering the formula Trying to eliminate trades entries being ignored resulting reversals ie should have reversed long, signal ignored, short remains and is covered some time later for loss. service log: BuyExit signal is ignored because Long position quantity does not exist or there are already working exit orders that will flatten the position. Current Position quantity with working exit orders: -1. Current Position quantity with exit market orders: -1 SellEntry signal is ignored because a Short position exists or working order quantities indicate a potential Short position, and Multiple Entries in Same Direction is not enabled. Position quantity: -1. Position with working orders quantity: -1 Date Time Of Last Edit: 2014-02-09 15:00:54
[2014-02-10 04:56:23] |
The formula was not written correctly. This is the correct format: =AND($J$8<=0,CROSSFROMBELOW(AH3:AH5,AI3:AI5) ) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-10 05:04:00] |
Litz - Posts: 131 |
Yes got it straightened out. I accidentally posted the topic twice and was addressed on the other thread.
